Product Warning Nokya Hyper-yellow Fog Bulbs
Old 10-04-10, 10:28 PM
EyeKutr
EyeKutr's Avatar
Default Product Warning Nokya Hyper-yellow Fog Bulbs
I've been running the hyper yellow Nokya 2500 bulbs for a while. They dont seem to last long and I've needed to replace each bulb once due to premature burnout....I was not surprised to see a bulb out this week so I went to swap my OEM bulbs back since this ***** is getting old....Look what I found....needless to say I am back to OEM now....luckly, the connection is still good and the OEM bulb works without me having to swap the wire harness (yet)
Old 10-04-10, 11:14 PM
GS350Lexus
GS350Lexus's Avatar
Interesting, i ran them on my Acura Tsx and they definatly didn't last long at all. But definatly my harness wasn't burning. I tried a lot of different brands and none of them actually last as expected. Best bulb goes to OEM then QUALITY HIDS KITS. Pick one and stick to it.
Old 10-05-10, 12:32 AM
rominl
exclusive matchup
rominl's Avatar
i guess at 70w you are pushing a bit on the harness, which is spec for 50w
glad to know that the stock bulbs are still ok. but careful on the harness, that pin is pretty weak now
Old 10-05-10, 05:52 AM
Yang1815
Yang1815's Avatar
Woah how long did you have to replace them?
I put my Nokya Hyper-Yellow in as soon as I got my GS in summer of 2007. They're still working fine.
Old 10-05-10, 05:53 AM
BinaryJay
BinaryJay's Avatar
Another reason to go HID, only 35W.
Old 10-05-10, 06:52 AM
passnu2
passnu2's Avatar
its the wattage isnt it? not the bulbs??
Old 10-05-10, 07:07 AM
Stormforge
executive matchup
Stormforge's Avatar
eyekutr, sorry to hear about your problem. but thx for sharing your experience, i will definitely not consider these bulbs for my GS.
Old 10-05-10, 07:22 AM
CAK 500
CAK 500's Avatar
That's what I thought too.
Old 10-05-10, 07:47 AM
worker
worker's Avatar
70Watt, no wonder. The highest you should go is 55Watt.
The OEM is like 35Watt, the next up is 55Watt and that said to produce 2x the lumen. I didn't see the different so contemplate on getting HID, finally did and now it works great. HID is 35Watt but I'm concern the starting period of HID.
35 watt normal run using around 12V and 3.2A while during start up period it sucking 5.5A for about 5mins. The fuse is about 10A so I think the whole wiring can handle it but than situation like yours cause some concern. When I get a chance I think I will buy a cable harness for my fog lights.
the 55Watt is rate at putting out 1.3K lumen, HID is spec 3K lumen. And I do see a huge different. Just don't turn it on/off too quickly.
Old 10-05-10, 08:33 AM
socal3gs
socal3gs's Avatar
Ebay hid fog kit work for me
Old 10-05-10, 09:01 AM
rominl
exclusive matchup
rominl's Avatar
stock halogen are 50w. 35w are hid
Old 10-05-10, 09:39 AM
worker
worker's Avatar
DDM for me.
Sorry, I was wrong... according to Sylvania all their 9006 are 55Watt.
Anyway, HID is a better choice and I gonna get a cable harness just to make sure this kind of burning won't happen.
Old 10-05-10, 09:50 AM
IXI187IXI
IXI187IXI's Avatar
exactly. the bulbs were doing their jobs, the car just couldnt handle it.
Old 10-05-10, 10:45 AM
worker
worker's Avatar
LOL
Watt is the unit for power. The Watt on the bulb indicate how much power the bulb rated to use (or sucks). Here, the bulb drawn too much power for the connector to handle so the connector burned.
Old 10-05-10, 10:53 AM
IXI187IXI
IXI187IXI's Avatar
well the good thing is that your oem bulbs still work. another member wasnt so lucky and melted his harness because of the same reason (using a higher wattage bulb then intended) and i believe the dealer wanted 1k to change out the fog wiring harness.
Quick Reply: Product Warning Nokya Hyper-yellow Fog Bulbs
