Cabin Filter - FRAM Fresh Breeze
Old 08-09-10, 07:22 PM
omniskye
omniskye's Avatar
Default Cabin Filter - FRAM Fresh Breeze
hi,
for the FRAM Fresh Breeze cabin filter, should the arrow be facing up towards the roof of the car OR down towards the ground?
the arrow points to what they label as "Air Flow", but i'm not sure the direction of the flow.
thanks for everybody's help.
Old 08-09-10, 07:26 PM
GSteg
GSteg's Avatar
I don't have a 3GS, but you can turn on the fan and feel the direction of the air.
Or wait til someone else response
Old 08-09-10, 07:28 PM
KevGS460ML
KevGS460ML's Avatar
Originally Posted by omniskye
hi,
It faces up towards the roof.
Old 08-09-10, 10:24 PM
omniskye
omniskye's Avatar
i just actually found another post right now in the RX forum that states the opposite....the arrow pointing DOWN. can you or anybody else verify?
"I also found the “FLOW” indication printed on the side of the filter confusing as the OEM has an “UP” along with an arrow printed. A quick look at the old filter indicated which way was “UP” (it was the opposite of the OEM). In other words, the OEM “UP” is up (like towards the roof of the car) whereas the Fram “FLOW” is DOWN (like towards the floorboard)."
HDD (04-12-17)
Old 08-10-10, 06:30 AM
greyhndfan
greyhndfan's Avatar
maybe you can call em'.
Old 08-10-10, 01:17 PM
3GS404
3GS404's Avatar
Arrow should face up the roof bro..
Old 08-14-10, 09:58 PM
94Supra
94Supra's Avatar
just look at the old filter to see which side is clean
Old 08-14-10, 10:46 PM
omniskye
omniskye's Avatar
the dirty side is the side that is facing up. i assume that means the air is blowing downwards. i.e., airflow is going DOWN?
however, i see the fan on the bottom side - unless it's pulling in air?
Old 08-14-10, 10:52 PM
GSteg
GSteg's Avatar
You're correct. Airflow is going down so the arrow should point down. It wouldn't make sense to for the fan to push air into the filter.
https://www.clublexus.com/forums/gs-...-07-gs350.html
HDD (04-12-17)
Old 08-24-10, 11:05 AM
motorking
motorking's Avatar
Default Cabin air filter
Hi,
I am the tech manager at Fram. All cars are different but a great rule of thunmb on cabin air filters is the arrow points opposite of the dirty side of the filter. We are actually considering replacing the arrow with the word "up" to help make sure they are installed correctly. Any other filter questions, i am happy to answer here or at jay.buckley@honeywell.com
Thanks for using fram!
HDD (04-12-17)
Old 08-24-10, 11:14 AM
RX469
RX469's Avatar
This is good to know. Thanks.
ayonnebay
07-25-15 02:21 PM
BrahmanLex
04-02-13 09:29 PM
sf3r8z
ES - 5th Gen (2007-2012)
12-04-10 10:26 AM
xfirechief
07-31-09 12:37 PM
notme
07-02-08 06:15 PM
Quick Reply: Cabin Filter - FRAM Fresh Breeze
