Potential Ballast Failure? Already??
my passenger headlight keeps knocking off and on every once in a while..... the passenger side HID would shut off until i flip the switch to the off position and back on. Anyone have any idea if this is the ballast or the bulb? and if it's the ballast, how much? i'm thinking of swapping bulbs with left and right and see how that turns out first, because if it's the bulbs... HELLO GARAX 6000k! =] if it's the ballast.... =[ hello big huge lexus bill
It's not that serious. Wear and tear, simple as that. You already know what needs to be done and if you need a new ballast check eBay or other car part places like the junkyard, etc. No need to hyperventilate over it.
that sucks brotha, hopefully i only need a bulb.... i have spare ballasts but i dislike the fact that i have to use a aftermarket HID ballast with my car =[
my ballast went out at 40k miles. i replaced it with a aftermarket ballast. i cut and spliced my oem harness and the aftermarket ballast to make it work. Now there is a company that makes a conversion harness that allows you to use a aftermarket ballast with the OEM bulb. The ballast is under the headlight.
http://www.hidextra.com/D2R%25252FD2...81+pcs%29.html
Sorry to bring back an old thread but it seems that no on has really found a solution to the problem. I just noticed the same issue tonight.. Driver side HID goes out.. turn it off, then back on and all seems fine.. but I have to do this every time I drive at night... really irritating..I have an 08 GS350..Someone shed some light on the situation please!!!
I heard that there might be a TSB lurking around somewhere? or am I just hoping? Looks like this has been an on going issue for alot of people.. but no one really has a hard solution to it.
That has happened to me before, with the xenons.
One on, the other off. Now it doesn`t happen.
Moisture inside the headlight as well., the left one.
Now the left foglight doesn`t turn on.
First the right one had the problem, turns out some wire was loose.
