Side Mirrors after placing in reverse problem
Old 05-28-10, 02:14 PM
levinsoy
levinsoy's Avatar
Default Side Mirrors after placing in reverse problem
I have a 2006 GS300 AWD fully loaded with ML and NAV. Just noticed that I may have an issue with the left side mirror when going into reverse (actuators to rotate them down do not return the mirror to original spot). Anybody have this issue? I'm out of the lexus warranty, how much to fix on one side?
Old 05-28-10, 02:54 PM
TWong350
TWong350's Avatar
super common. use the search tool and you'll find this complaint has to do with the plastic gears inside of the mirror. You only choice is to get a new mirror from the dealer (or a used one from ebay). The gears aren't sold separately. Good luck!
Old 05-28-10, 04:02 PM
rominl
exclusive matchup
rominl's Avatar
yup, pretty common on lexus. they don't have replacement gear, only the whole assembly and you probably don't want to know the price.
i say try ebay and try to find a junk one for replacement
Old 05-28-10, 07:16 PM
Bavaria
Bavaria's Avatar
How about setting the mirrors where you want them and disabling the reverse feature?
Old 05-28-10, 08:04 PM
heyitzalex
heyitzalex's Avatar
I got the same problem...
Old 05-28-10, 08:50 PM
fatLEXUS
fatLEXUS's Avatar
I got the same problem too... I just don't want to buy an expensive item. trying to save up for some speakers :P
Old 05-28-10, 08:54 PM
GS350Lexus
GS350Lexus's Avatar
I had exact same problem, i went to the dealer and had the both mirror assemblies replaced under warranty. If you are off the warranty i feel bad for you its $1,500 a mirror.
Old 05-29-10, 08:01 AM
varcity64
varcity64's Avatar
i have a similar issue and on top of that, my mirrors dont even go down when i put in reverse (i make sure that i have the left or right side light on to enable the feature) and have taken my car to lexus twice already for this. the first time, they claimed it was working properly. the next time, they acknowledged it was a problem but only greased the gears as they said it was extremely dried out. that worked exactly 6 days. now i have my 3rd appt next week to (hopefully) reslove this issue. i have an 07GS350 AWD with 62k on the ODO, but an extended warranty from lexus so this should be covered
Old 07-27-10, 09:24 AM
mcruiser
mcruiser's Avatar
I have same issue, does anyone have any idea on how to disable the mirror reverse feature? There should be a connection from the mirror to the reverse gear.
Old 07-27-10, 09:31 AM
GS4_Fiend
GS4_Fiend's Avatar
Isn't that feature just useless and annoying? should just disable the feature. Nobody needs to see the ground anyhow.
Old 07-27-10, 09:39 AM
IXI187IXI
IXI187IXI's Avatar
if you dont want the mirrors to tilt down then on the drop down box, set the switch to the middle so neither the L or R is selected. doing so will stop the mirrors from tilting down in reverse.
Old 07-27-10, 10:50 AM
cunningham
cunningham's Avatar
happend to mine also, try the dealership and see if they will fix it for free if you are over warranty, they do that some times. In socal, try westminster lexus. huge facility and they do a lot of comped service
Old 07-27-10, 12:11 PM
energie8
energie8's Avatar
I had that problem 2 weeks ago and then I just tapped/smacked the glass a few times(do it at your own risk) and the motor started moving again...lol
Old 07-27-10, 01:05 PM
rominl
exclusive matchup
rominl's Avatar
it will come back again. trust me, happened on both mirrors on my sc430
Old 07-27-10, 01:49 PM
MadDawg350
MadDawg350's Avatar
YES SIR!! Both mirrors on the RX330 I once owned, and both mirrors on my 07 GS350
Quick Reply: Side Mirrors after placing in reverse problem
