Tire Sizing advice needed...please
Old 05-18-10, 09:00 AM
rominl
exclusive matchup
rominl's Avatar
if the wheels fit on the gs430 with no fender mods, it should fit on 350 as well. just the tires need to be changed
Old 05-18-10, 04:00 PM
msgs350
msgs350's Avatar
Thanks guys! I went ahead and ordered 235/35/20 tires for the fronts to keep the rolling diameter close to 275/30/20 for the rear. I learned PLENTY from this thread about tire sizing and risks for not making the rites match on an AWD.
Now....if i could only understand how offsets are calculated....
Old 05-18-10, 05:19 PM
rominl
exclusive matchup
rominl's Avatar
http://www.tirerack.com/wheels/tech/...jsp?techid=101
here's a start. and as to how to get good offset info say for the 3gs, then it's a lot of references, calculations, experience, and trials
Old 05-19-10, 01:20 PM
mr3gs300
mr3gs300's Avatar
ok in a tire calculator I tried 245/30/20 front this is almost perfect 275/25/20 is lil more off
http://www.1010tires.com/TireSizeCal...?action=submit
Old 05-19-10, 01:34 PM
IXI187IXI
IXI187IXI's Avatar
you'll never find 2 the exact same. tire heights are all based of percentages. the 2nd number is the percentage of the first number. ie, 245mm wide and the side wall height is 30% of 245mm's.
Old 05-19-10, 01:55 PM
mr3gs300
mr3gs300's Avatar
ok so what is the widest tire I can run on a 06 GS300 awd cause when I redid the size with a 285/25 its more spot on then the 275/25
step2me
03-27-12 10:12 PM
yangaroni
GS - 1st Gen (1993-1997)
03-08-12 04:26 PM
Charlie088
02-21-12 02:17 PM
Jasoneo5
Wheels, Tires & Brakes Forum
05-13-05 02:27 PM
MikeGS4PE
03-27-01 05:03 AM
Quick Reply: Tire Sizing advice needed...please
