Nail or Screw in my run flat?
Can I get my run flat tire repaired/plugged from a nail or screw like a conventional tire? I picked up a huge screw or nail yesterday and it is still in the tire. I have never had run flats before so I am not sure if they are repairable. Thanks,
I faintly remember someone said run flat are not suppose to be fix in anyway.
Anyway, I never had and never will consider using run flat. Many ppl said it's noisy/heavy/and doesn't help much. Many ppl here even sell their run flat exchange for regular tires. Normal tire and a spare in my trunk is good enough.
exclusive matchup
but say you got a nail, you aren't actually leaking much air (say instead of 33psi, you are at 31psi). the tire is still "ok" in that term
exclusive matchup
but the whole idea of runflat is even at zero pressure, you can go at 60mph for like 100 miles? during this time, the tire actually "look" very normal. but internally it's actually riding on rubber and the heat will tear the tire apart. in that case, the tire is trashed
stevelifts
04-10-18 06:35 PM
