Tires for 18 x 8 Machine Tourmaline wheels
Old 10-26-09, 06:32 PM
steviej
steviej's Avatar
Originally Posted by bimori
thanks just making sure I didnt goof by ordering the 18x8 Tourmaline's. If there were a fix for it, what would it be? and is it on all 4 tires or only the front??
I only hear it on the left front and have only found wear marks on the left front. It doesn't happen if the front end doesn't dip while braking and turning at the same time.
Old 12-23-09, 05:15 PM
Evel
Evel's Avatar
Default Tire Wear from Scrubbing?
Originally Posted by echelon
Nope my car's not lowered. I have the exact problem steviej has. It's really not that bad it very rarely ever happens, my wife never notices it so I don't feel the need to do anything about it.
Okay, so I'm near the end of a 2nd set of the Dunlop 5000ST (whatever) run flat tires that I obtained from GS430, when I purchased by GS300AWD. Now in the fiirst year of purchase Feb. 06-07 I had a lot of drifting & alignment issues & the original tires had abnormal inside wear. Lexus checked out suspension in June '07 & said I likely received a bad set of runflats & gave me a new set of the same tires. After the dealer performed some TSB's on the car in April, I began hearing a swooshing/rubbing sound from the front tires at very low (going thru fast food drivethru speed). The dealer said its the noise from the run flat tires as they age. Fast forward to Nov & oil change & tire rotation & I'm told I have abnormal inside wear on the two front tires (now rotated to the back). So based on this thread, it appears it is possible that the inside wear on the original & replacement sets of tires was caused by rubbing against the wheel well liner. Has this been confirmed & if so, has anyone had any success with getting a Lexus dealer to address it?
Rezno
07-15-17 09:49 PM
Gville350
08-31-12 11:01 AM
OneOfOne
Wheels, Tires & Brakes Forum
09-30-04 05:19 AM
Brett
12
06-07-04 07:54 PM
Shinchan
11-19-01 02:31 PM
Quick Reply: Tires for 18 x 8 Machine Tourmaline wheels
