This Forum is Sponsored By:
Go Back   Club Lexus Forums > Lexus Model Forums > GS Models > GS - Third Generation
Thread Tools Display Modes
Old 08-14-09, 08:55 PM   #1
mikewho84
Trader Score: (0)
Default Rim fitment?
I orginally bought a set of 19" Work Euroline DZ for another car that I had, but now I recently brought home a '06 GS300 AWD. Kinda wish I did my research and looked for a RWD. Anyways I'm trying to get opinions on how the offsets would look on the car. The offsets are 19x8+35 and 19x9+30, and if need be I'll add some spacers. Here is pic of actual rims. Thanks in advance.
mikewho84 is offline   Reply With Quote
Old 08-14-09, 11:09 PM   #2
SNiiP3R
Trader Score: (0)
SNiiP3R's Avatar
The front is fine, the rear is a bit low I think. If you're not going to lower your car then it may work
__________________
As I said before, I never repeat myself!
SNiiP3R is offline   Reply With Quote
Old 08-15-09, 01:12 AM   #3
rominl
exclusive matchup
Trader Score: (2)
rominl's Avatar
9+30 is the same as 10+42, if you use 265 tires i think it will be ok
__________________
- Do it once and do it right. Do your homework to get it right.
- If you can't afford it, drive the car stock.
- promoting knock-offs is shameful on a car enthusiast site, not to mention companies who make/sell knock-offs.
- it's authentic if it roots from the original company
rominl is offline   Reply With Quote
Old 08-15-09, 04:00 AM   #4
mikewho84
Trader Score: (0)
Quote:
do you mean if i lower the car?
Old 08-15-09, 09:33 AM   #5
SNiiP3R
Trader Score: (0)
SNiiP3R's Avatar
After reading rominl's comment, I think you should be fine either way.
__________________
Old 08-15-09, 11:41 AM   #6
mikewho84
Trader Score: (0)
Quote:
265/35/19 should be for the rear? what about the front?
Old 08-15-09, 10:46 PM   #7
rominl
exclusive matchup
Trader Score: (2)
rominl's Avatar
with 8 and 9, umm.... maybe i will do 235/35 and 265/30. a bit on the small side but the wheels are narrow so personally i try not to put 245/35 and 275/30
__________________
Old 08-16-09, 09:02 AM   #8
enigmaos
Trader Score: (2)
sorry for thread jacking, but I am in the same situation - 18x9 +31mm all around going on a 3G GS + stock suspension + AWD.
Based on the specs provided by rominl, they should fit with 245/40/18s? or I need 225/40 or 235/40 for front?
enigmaos is offline   Reply With Quote
Old 08-16-09, 10:35 PM   #9
rominl
exclusive matchup
Trader Score: (2)
rominl's Avatar
9+31 that's quite aggressive on the front, just keep that in mind
__________________
Old 08-17-09, 05:10 PM   #10
enigmaos
Trader Score: (2)
yeah, that's my concern. I hope they won't rub.
Old 08-21-09, 06:16 PM   #11
mikewho84
Trader Score: (0)
would that be a good fit? i'm trying to stretch the tires, so it'll have that aggresive look
Old 11-04-09, 07:16 PM   #12
enigmaos
Trader Score: (2)
245/40/18 should be fine on 9+31?
Old 11-04-09, 07:34 PM   #13
rominl
exclusive matchup
Trader Score: (2)
rominl's Avatar
Quote:
imho it might rub
__________________
Old 11-04-09, 07:49 PM   #14
enigmaos
Trader Score: (2)
Thanks. I guess it's safer to run 235/40/18s.
Nobody has this setup or similiar setup?
Old 11-05-09, 12:45 AM   #15
memasterac
Trader Score: (0)
memasterac's Avatar
9 +30 is near identical to 10 +42. When you say it will be ok, meaning without any modification to the fender/wheel wale inner plastic or clips? knowing when compare to stock, a 265 tire is 10mm more & the wheel is about 28mm more to each side of the wheel/tire?
I ask because I had a 20mm spacer on the rear stock 18" wheels and 245/40 tires but it rubs a bit when hit big bumps. I downgraded to 15mm then no rub at all. My GS is slightly lowered and No fender mods.
__________________
07 GS350 - ings+1 - Lumarai - TEIN
memasterac is offline   Reply With Quote
Tags
car, dz, euroline, fitment, lexus, rim
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
