How to clear my "Low Tire Pressure" warning light.
Old 08-02-09, 01:05 PM
AUTOBAHN
AUTOBAHN's Avatar
Default How to clear my "Low Tire Pressure" warning light.
I recently purchased a 2008 GS350...LOVE IT!
My "Low Tire Pressure" warning light turned on, so I added air according the owner manual's specs (33 psi). Now that AlL FOUR tires are properly pressurized, I would like to know how to clear the warning lights.
Any advice??
Old 08-02-09, 01:24 PM
apok003
apok003's Avatar
If I remember, you just drive around for like 5 min, and it should go away on it's own..
Old 08-02-09, 01:57 PM
ek9vboi
ek9vboi's Avatar
Nothing. Just drive it and it will go away.
Old 08-03-09, 02:44 PM
rominl
exclusive matchup
rominl's Avatar
sometimes it might take a few miles of driving (or 10-15 mins) for the light to go away, though usually it should be pretty quick
Old 08-03-09, 06:27 PM
steviej
steviej's Avatar
did you try reinitializing the TPMS system. instructions are in the manual.
also check to make sure the Main/Set B switch didn't get accidentally set to the other position. That will cause the light to come on too. Happened to me when a friend shoved there backpack up inder the passenger dash.
steviej
Old 08-03-09, 07:25 PM
arnieosp
arnieosp's Avatar
Did you check your spare tire? I think it also has the sensor. Make sure it has the same pressure.
Old 08-04-09, 07:46 PM
steviej
steviej's Avatar
I do not think the compact spare has a sensor in it. At least mine doesn't and the ECU is not looking for a sensor signal from that wheel.
steviej
Old 08-05-09, 07:50 PM
tommyd3
tommyd3's Avatar
steviej
I know for a fact that the LS has a sensor for the spare and according to my dealer service consultant the GS does also. I loose more air from the spare than the others since it is supposed to have 60 psi!!!
Old 08-05-09, 08:49 PM
LMN_Sins
LMN_Sins's Avatar
everytime my tire pressure light comes on i just put air in and the light turns off right when it hits the right psi... and i dont believe the GS has a tpms sensor in the spare, unless you have a full size spare....
Old 08-05-09, 10:33 PM
rominl
exclusive matchup
rominl's Avatar
the donut spare in the gs has a rubber valve tube, you sure it has tps? i highly doubt that
ls460 has full size spare and it has sensors (metal valve tube just like the other wheels)
Old 08-06-09, 05:19 AM
passnu2
passnu2's Avatar
maybe you have a nail in a tire?
jrs21c
11-27-19 07:39 AM
Moonstruck
07-02-14 01:47 PM
snakehead
03-21-10 10:03 PM
dlap
03-07-10 06:24 AM
lynn
02-19-07 11:27 AM
Quick Reply: How to clear my "Low Tire Pressure" warning light.
