Bluetooth audio streaming
Old 06-29-09, 12:34 PM
hieu
hieu's Avatar
Default Bluetooth audio streaming
is there any way to update firmware to stream audio over bluetooth in the 2006 gs?
Old 06-29-09, 09:26 PM
Leeladisky
Leeladisky's Avatar
Nope.... none of the GS's have this option, so this feature doesn't exist.
Old 07-11-11, 07:55 PM
sxwk12
sxwk12's Avatar
This thread is over 2 years old. Has Lexus made a change to this? Is there a firmware upgrade for it now?
Old 07-12-11, 02:43 AM
IXI187IXI
IXI187IXI's Avatar
only on the newer 2010+ which is running the gen 6 system
Old 09-01-11, 07:48 PM
IIKings920
IIKings920's Avatar
My buddy got an aftermarket add on (Dice I think) for his 06 LX 470 and it connects into the factory stereo/NAV and works perfectly.
Old 09-03-11, 08:49 PM
ingoodtime
ingoodtime's Avatar
Really sad that on a 50 grand car, Lexus cant upgrade the firmware.
Old 09-04-11, 07:16 AM
Harlemboi
Harlemboi's Avatar
I'm using the "blackberry gateway" to stream audio (with an iPhone) thru bluetooth on my Gs and I love it!!! Works perfect!!
Old 09-05-11, 01:04 PM
jgr4444
jgr4444's Avatar
can you explain this? what is a blackberry gateway?
Old 09-06-11, 05:50 AM
Harlemboi
Harlemboi's Avatar
"Play music stored on your BlackBerry smartphone wirelessly through your stereo system with the BlackBerry Remote Stereo Gateway. To wirelessly transmit your music, simply connect the BlackBerry Gateway using the accompanying 3.5mm stereo cable or RCA auxiliary cable to your stereo system, turn on the gateway, pair your smartphone, and that's it!"
http://www.google.com/search?q=black...&client=safari
Old 09-06-11, 06:01 AM
little2576
little2576's Avatar
Where do you connect the 3.5mm stereo cable or rca aux cable to ? Is that in the rear of the radio/nav ?
Old 09-07-11, 07:18 AM
Harlemboi
Harlemboi's Avatar
Oh yea sorry, you need some type or aux input to use the gateway! I'm using the " JL cleansweep" for my aux integration for my car cuz I have a system in my car. But there are a bunch of aux intergrations for the gs300 that u can use and then plug the gateway to that unit
Old 09-07-11, 07:47 AM
IXI187IXI
IXI187IXI's Avatar
if you have an 08+ there is an aux input
Old 09-08-11, 08:33 AM
little2576
little2576's Avatar
found this out when i got a loaner
Old 09-09-11, 07:02 AM
KILLERGS4
KILLERGS4's Avatar
personally I think iPod Integration Kit is better than Bluetooth, or if you wanta be cheap use the iCarplay Cassette Adaptor. With Bluetooth audio, you have to use the device to change your music vs using the touch screen interface.
Old 09-09-11, 03:48 PM
memasterac
memasterac's Avatar
For 2007 and 2006 GS, you can use a cassette tape adapter.
Quick Reply: Bluetooth audio streaming
