Flasher Location
Old 05-29-09, 08:16 PM
Leeladisky
Leeladisky's Avatar
Default Flasher Location
Can someone, anyone plese post pictures of the service manual page(s) that show the turn signal flasher pinout and location? I am looking to do a DIY on how to replace it with an LED module to reduce flash rate, for those of us who have replaced their turn signals....
Load resistors are just a heat source so I'm looking to do this the right way....
any pics or comments welcomed.
Lee
Old 11-03-11, 06:54 PM
arnieosp
arnieosp's Avatar
Sorry about bringing back the old thread, but did you ever find the flasher location?
Old 11-04-11, 07:58 AM
CAK 500
CAK 500's Avatar
I installed this about a year ago. Does the job.
http://www.v-leds.com/BlinkerWarning...57253-1-3.html
Old 11-04-11, 08:51 AM
arnieosp
arnieosp's Avatar
Thanks. So, where is it located and how did you get to it?
Old 11-04-11, 09:08 AM
TWong350
TWong350's Avatar
Here's a screen shot and I've also attached a PDF that might help. K25 is the flasher.
File Type: pdf
Old 11-04-11, 11:20 AM
arnieosp
arnieosp's Avatar
Thank you very much.
So, correct me if I am wrong, but the easiest way to get to it is to pull out the instrument cluster and its right behind it. Also, do you have a list of all other relays in this picture?
Pupule7 (04-17-21)
Old 11-04-11, 11:34 AM
TWong350
TWong350's Avatar
It certainly appears that way. You can also try to look from the footwell area to see if you can shine some light and see if you can see it or not.
Download the PDF that I attached and you'll see a legend to all.
Old 11-04-11, 11:44 AM
arnieosp
arnieosp's Avatar
Got it, thanks.
So, before I rip the instrument cluster out, is there anybody out there who had done the flasher relay replacement? How do you get to the darn thing?
Pupule7 (04-17-21)
Old 11-04-11, 04:17 PM
CAK 500
CAK 500's Avatar
No need to remove anything. It was a bit of a limbo maneuver for sure, but I was able to reach up behind the dash and make the switch. You'll need a flashlight and plenty of patience, but it certainly beats pulling the dash apart.
Old 11-04-11, 09:00 PM
Lex Luga
Lex Luga's Avatar
Is it easy to replace the front blinkers? I know the rear blinkers are real easy to replace
Old 11-04-11, 09:16 PM
arnieosp
arnieosp's Avatar
Thank you very much for the info.
Old 11-28-11, 11:14 PM
arnieosp
arnieosp's Avatar
Okay, I replaced the turn signal light bulbs with LEDs and also replaced the relay. My turn signals blink at normal rate, but when I lock/unlock the car it still beeps, but the 4-ways don't blink anymore. Is this a collateral damage?
Old 11-29-11, 01:47 AM
twylie
twylie's Avatar
This is a known side effect of the LED blinker bulbs and flasher unit swap and the only thing that has kept me from doing it as well.
Old 11-29-11, 12:20 PM
arnieosp
arnieosp's Avatar
Thank you for the quick response. I guess, I can live without the alarm blink. The LED turn signals look really cool, so I am willing to sacrifice the blink.
Old 03-07-12, 07:00 PM
uptownboi
uptownboi's Avatar
VLED claims that parking 4led flash confirmation works with this flasher.... does it work on the GS?
Quick Reply: Flasher Location
