I've got everything installed and wired, but the green wire (in passnu2's pic) is definitely not the passenger side turn signal in my '07. It lights up the leds with a steady 12v, while the other signals flash normally. The yellow (drivers side) works like a champ though.
Yes, there are several greens for sure, but only one thick green as you described in post #65.
How did you test to find which wires in the first place? I don't want to start cutting into wires just to test them unnecessarily if there is a less intrusive way.
__________________
'06 GS300 ML / NAV , VAIS SLI, LED side mirrors (DIY), BT Nav bypass (DIY), Pics of my car
'04 GX470 ML / Nav / 3rd Row / XD 6000k HIDs
^ sorry I wasnt back on. Yes I had a volt meter to test the wires. No guessing.
Post back if you have issues. Will help you figure it out. All the wire diagrams I saw showed the models where the same so I will be shocked if its truly different.
I'm thinking about getting this JDM side mirror lights for my 07 GS350. However, i'm not sure what color to tell the vendor the paint. I have a white (starfire pearl white is the correct name?)
