Road Magnet Spring / Made for the AWD GS
#61
the gs awd have a very slight vibration. i sat in a 2008 gs and it had a vibration at gear but being dropped on awd enhances the vibration.
i am gonna feel better being on awd springs than rwd springs.
#62
The only reason that I see an advantage of using the Road Magnet springs is that they are specifically designed for the "AWD" version. Please correct me if I am wrong but I think that you will achieve the same result as a Tanabe NF210 or equivalent Tein manufactured spring. Also, the only reason the Road Magnet springs specify a lower drop than the Tanabe NF210 is because the AWD sits approx. .50" higher than the RWD versions. I wouldn't be surprised if Road Magnet just reverse engineered the Tanabe NF210? I just don't think a lowering coil spring replacement from Tein/Tanabe to Road Magnet will prevent the vibration.
#63
well its been like 6 months since i had my stock springs on and i did not have any vibrations. what else can it possibly be if not the springs. maybe i have a slight bend on one of the rims on the right side of the car. well like i said before i slid in to a curb hitting both wheels. when i went to lexus i told him i have a vibration and he showed me how both the rims on the right side were wobbling, so i paid for one wheel and my guy said he gave me the other rim under warranty, and i was on stock springs. maybe they looked for a way on saving or something. ill have my rims checked out just incase i am going thru all this because of the wheels.
let me ask, your on awd dropped springs and you have no vibration issues at all on the highway or on brake..
#64
After you hit the curb are you 100% sure that no suspension/steering components were damaged?
#65
the tech told me that they changed the hub bearing the axel if i am not mistaking and the 2 side wheels. when i accelerate the vibration hits like at 40 - 50 and on the highway accelerating from 70 - 80 on pickup. i feel like the more people i have in the car the quicker the vibration hits due to weight..
i would love to put my stock springs on and take it on the highway but it will be a job and half to put the stocks on try it out and then drop the car again. if i do that it would be the 5th time changing my springs back and forth :/
#66
#70
Has anyone still determined how these springs differ from any other springs out there? As far as I'm concerned, the fact that they are "made for the AWD GS" is just a marketing technique until I see some actual physical design differences.
#72
Exactly! What we need to see is the actual spring rates. Like I mentioned earlier, these are probably just reverse engineered Tein or Tanabe NF210 springs.
#73
#75
You have a staggered 20" wheel setup too? Like I mentioned previously, I think the vibration observations are subjective. I'm going to try an obtain a vibration analysis instrument so we can quantify the level of vibration. I know of another GS300 AWD owner that's lowered on staggered 20's. Once I get the instrument I will measure both of our cars. If there are any other GS300/350 AWD owners in the SF Bay Area let me know?
