larger in terms of diameter, however the calipers aren't as thick as the gs350 brakes. someone already test fitted the is-f wheels on is350, which has the same brakes as gs350. just as i first guessed, the wheel spokes don't completely clear the 350 calipers
Correct, it was JoeZ that tested the IS-F rims on his IS350. The front caliper is a little larger in terms of size than the IS-F Brembos. The IS-F brembos are defined vs. the 3GS/2IS front brake calipers being a raw undefined block of metal. So no they wont fit on unless you push them out with spacers.
