Navigation Route Guidance
Old 06-12-08, 12:46 PM
valgs350
valgs350's Avatar
Default Navigation Route Guidance
Well for the past month my navigation has had a problem. When I enter a a addresse and push guide it will say something like "Go on route and wait for guidance."
It shows the line/direction I need to take but when my car goes on-route it will not guide, when I use voice command "repeat guidance", she says "not under route guidance."
So then I have to zoom out of the map and keep an eye on the screen to see how to get to the location I need to be and if I go off-track it will not recalculate the route.
What can I do to solve this problem?
I tried to recalerbrate the location but it doesn't seem to have any affect!!!!
Old 06-12-08, 01:00 PM
The G Man
The G Man's Avatar
It sounds like your nav cannot pin point where you are. Maybe a reciever or antenna problem, I would let the dealer fix it.
Old 06-12-08, 01:15 PM
EyeKutr
EyeKutr's Avatar
This happens when it does not know exactly where you are at or have the bypass switch in the bypass mode.....you flip the switch back right? Does it do it with the switch off as well? Are you on the map in the correct spot? try calibrating the thing under menu as well
Old 06-12-08, 01:17 PM
The G Man
The G Man's Avatar
What bypass switch?
Old 06-12-08, 01:22 PM
whlkev
whlkev's Avatar
Originally Posted by The G Man
What bypass switch?
the OP had his Nav modded...
Old 06-12-08, 01:23 PM
EyeKutr
EyeKutr's Avatar
G man, he has a nav dvd bypass.....
Old 06-12-08, 05:54 PM
valgs350
valgs350's Avatar
I will try that!!!!
I'll let you know the outcome!!!!!
Old 06-12-08, 06:15 PM
valgs350
valgs350's Avatar
LOL....the switch was flipped the wrong way!!!!
Thanks
Old 06-12-08, 08:20 PM
EyeKutr
EyeKutr's Avatar
Val Val Val .....LOL Its nice to know my solder did not come apart LOL
Old 06-13-08, 05:27 AM
The G Man
The G Man's Avatar
So if its in bypass mode, the nav will not guide?
Old 06-13-08, 07:31 AM
EyeKutr
EyeKutr's Avatar
It may or may not, VSS input is needed for best guidance performance, bypass kills the VSS input (this is for wire hack)
Old 06-13-08, 09:56 AM
ecount00
ecount00's Avatar
I have the plug n play kit and same concept. it interupts the signal, making the car think it's not moving so the system unlocks. once you finish the address input and turn it off, you notice the system hasn't been tracking while in override. takes a few seconds for it to figure out where you really are.
Old 06-13-08, 10:25 AM
The G Man
The G Man's Avatar
Anyway to get to this VSS wire without taking the dash apart?
hms09
10-01-14 06:11 PM
Modeler
11-16-10 01:44 PM
hojin4eva
02-09-08 06:37 PM
optsgirl
05-28-07 06:19 PM
my06GS300
03-18-05 01:02 PM
Quick Reply: Navigation Route Guidance
