Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
- Lexus: How to install HID Headlights (on your non-HID equipped 2IS)
Step by step instructions for do-it-yourself repairs
DIY - GS fog light replacement
#46
I looking to change the fog lights to NON HID - going with nokya 9006 artic/jdm yellow.
I dont have to worry about OEM housing and wire harness melting or reacting to a higher wattage output?
Do I need the wire harness that some sites sell with the replacement bulbs?
#47
If you're using the same wattage bulbs, I don't see why you would need to change anything besides the bulbs. On an off-note, changing to HID fogs would cost about the same and usually last longer. They also run cooler if you're paranoid about melting housings and harnesses. And of course, they're twice as bright.
#49
Also, On a side note, I am assuming my stock HID's are 4300k??? So the conversion kit would get my fogs to the exact same color as the stocks?
Thanks for the help guys.
-D
#50
#51
Nice! Thanks for the link. One thing I noticed was there wasn't anything mentioned about the kits from HIDXTRA having relays... I have heard from other people that without a relay, there are chances of the HID's not coming on right all the time if the fogs aren't delayed from the low-beam HID's. Any comments on this?
#52
I ordered the HID conversion from HIDextra and should be getting them in withing a couple of days. I started looking the fogs over to see how hard it was going to be to do the change. I tried searching for a DIY on changing out the halogen's with HID's but havent had any luck. Does this exist?
If not, my biggest question is... Do I need to remove that surrounding on the inside of the lens that covers the halogen bulb? If yes, how do I do this?
Thanks,
-D
Thanks,
-D
#53
Thanks,
-D
Thanks,
-D
#54
Relays can be purchased at the same site, but not necessary. Most people don't use relays including myself and works fine. You don't need to remove anything. All you have to to is turn the wheel. Loosen a feel clips and feel back the wheel well splash guard. It's as easy as changing a bulb, except you have an extra you have to stick somewhere.
P.S. I can only imagine how annoying HID conversions would be, even in fog lights, if people took out the reflector shroud from the housings. I think the glare coming off of them without that would be extremely ridiculous.
I apologize for not taking pictures yet. I keep my car in an underground garage with strong fluorescent lighting and I just haven't had the car out on a clear night by myself yet (and haven't bothered to take it out of the garage for the express purpose of taking pictures). Maybe this weekend I'll do it since I have a new camera (Panasonic ZS3) getting delivered today that I'll want to test the HD video recording out on... so I'll do one better than pictures and record a video showing how the lights (Putco LED and XenonDepot 3000k) look from a few angles if that'll help anybody make any decisions about what they want to do with their cars.
#56
I really don't see any "risk". The HID kit uses less wattage than standard halogen 9006 bulbs. The relays are there in case your vehicle provides unreliable amounts of power to the harness, in our case, it seems to do this just fine.
#57
Agreed. From what I found, the only "risk" of not using relays is that you the car may have troubles with getting all the HID's ignited correctly. I did not use relays as I was recommended not to and they work just fine with absolutely no problem firing all HIDs at once. I do have a friend with a GS430 and he had to use the relays. He would run into occasions where only one of his fogs would fire and that cleared the problem up for him. I guess Lexus improved their power delivery in the later years.
