LED Trunk Lights Hack
Tapping in?
Ok, I bought some 1/2" #4 Sheet Metal screws, which are a bit snug but should work.
Second question: how did you tap into the existing light? I found the plastic panel behind the tail light, and can feel behind the trunk light. Did you remove it? If so, how? Where exactly did you tap into the power to the trunk light?
Two approaches I can see are to tap into the light unit itself, or to cut back some of the sheathing on the wire harness and use crimp-on taps there.
Any thoughts appreciated...
Just get the smallest screws you can find that will fit the holes in the LEDs and that are about 1/2in or less..
Done!
Thanks for posting the hack!
Here is my version
I ordered a second light housing at the dealership, it is identical to the current one in the car. I ran the wire under the trunk roof lining and placed the new light on the left side, up high. I used a blade knife to cut a hole same size as the one on the right side (used masking tape to delineate the perfect cut). The plastic / felt lining is rigid enough that the light fits nicely and wont rattle out. Then I replaced the bulbs with 31mm 9 LED festoon bulbs (white0, EBAY item 200073126196. The 31 mm bulbs dont fit unless you bend the arms a bit using 2 needlenose drivers, but if you do it right it will still turn on and off using the switch. Sorry pics are blurry, they are w/o flash except last one.
wow, nice idea.
Just by looking at the pic, you should send it to Apple or any notebook company...
On yours, the setup seems created any spotlighted area but letf the rest of the area in dark.
I am sure it will be useful for peeps who usually do "transactions" in trunk, but I hardly open it.
Good moding spirit!
Good moding spirit!
EyeKutr- do you have the part # for Lexus light you used? I like the hack and will probably do the same in my wife's new GS (once it gets back above 0 here!!!)
Also, did you solder the second light's lead one onto the OEM one so they both work off one switch, or did you just tap into the line?
Great mod and thanks in advance!
I dont have the part number at hand, i thought the housing was a bit expensive but what do you do? Just have them order you the "trunk illumination light housing" Here is the catch, that part obviously DOES not include the plug that brings the power in, so that i had to get some slip on connectors . Also see how much bigger the 31mm LED is....
The wire I ran to the left side of the trunk was spliced in, that means each switch is independent and functional. To sum it up
1) pop off light housing - easy to do with standard screwdriver inserted right by the switch.....
2) get new housing & 2 31mm LEDs
3) rig up the mechanism to accept longer bulb - see pic
4) run a wire from right side to left
5) cut a hole for new housing
6) install quick connects onto the tips of the wire so it can slip on securely
7) splice in at the right side and youre done
Thanks again - looks awesome! Hopefully the snow (and thus salt / cinder crap) will stop soon here. Picked up our new GS350 last friday w/ 5 mi. Brought it home and it hasn't moved since - we're up to all of 16mi!!!!! Maybe this weekend, maybe this weekend......
or you can turn them both off and they won't come on when you open?
mind taking a pic of the quick connects attached? What wire did you buy to attach the left light to the right? about how long was it?
just asking, b/c I ordered 2 exact bulbs today, and placed order for light housing from lexus yesterday.... too bad the allumination light housing was 49.50 from my lexus dealership. bah. oh well, they are shipping directly to my house....
I want this install to be just an extra light, that will work as the original standard light. Meaning they "both" go on and off as did the one that came with the car, when I open and close the trunk...
thanks.
Jason
