blurry cutoff line
Old 07-25-06, 05:26 PM
luciush
luciush's Avatar
Default blurry cutoff line
has anyone tried putting a clear lens on your projector, so that you can achieve a sharp cutoff line and maybe a even better output?
i cant stand how blurry ours is
Old 07-25-06, 06:29 PM
jwa
jwa's Avatar
It might be easier to have your eyeglass prescription changed.
Old 08-20-07, 02:40 AM
Shon.nv
Shon.nv's Avatar
Bringing this thread from the dead. Color modding the projector is pretty easy. The reason behind the blurry cutoff is the fresnel lens. Iam assuming that the projector is the same as the RX330 cause I havent seen the GS projector yet and if so, it can be modded easily to get this result
from about 25'
Old 08-20-07, 02:45 AM
ILOVEGIRLS
ILOVEGIRLS's Avatar
hmm..im not sure if i wanna bake the new headlights yet...
Old 08-20-07, 02:49 AM
Shon.nv
Shon.nv's Avatar
^^ Get a spare and just work on that. The best and the safest way to go, after you are done with the spare, sell the original ones
Old 02-11-09, 07:34 AM
9aristo
9aristo's Avatar
i'm reviving this thread again lol...
just got my GS350 and just installed my Garax 8000K D4sS bulbs and realized the blurry cutoff too... Before I jump on ebay for oem projector lens, anyone have a clue as to what size the projector lens are? I used to have a 2001 A4 with ecode headlights (very awesome output and cutoff i must add) and I am definitely going to attempt this swap. I much rather order the lens first, then start the project rather than take the headlight apart to measure and do twice the work by putting it back together to wait for the part...
Old 02-11-09, 07:43 AM
ELL Y
ELL Y's Avatar
most likely the projector is a 2.5", but even amongst projectors of comparable size, lens will not fit the same. For example, a TSX lens is much too small to properly fit in my SC430 projector, and requires special spacers to evenly center. A bmw e30 lens fits perfectly.
As for buying "oem projector lens", i'm not sure what you mean by that. I don't believe there is an OEM clear lens for that vehicle, or most vehicles for that matter. You could either get a different car's clear lens that fits (E30 maybe, TSX, ZKW, etc) or attempt to clear the stock lenses yourself using clearcoat (Someone did this over at HIDPlanet. You can do a search).
Good luck
Old 02-11-09, 07:46 AM
ELL Y
ELL Y's Avatar
I should also add that blurry cutoffs are easier on the eyes, since there isn't as sharp of a contrast, and therefore preferred by most OEM manufacturers
Old 02-11-09, 08:16 AM
9aristo
9aristo's Avatar
lol cool. I meant oem as in lens found originally in other make's original headlights. so 2.5". I wonder if my old A4 projector lens will fit. Well i'm going to study my headlights first (only had the gs350 for about 2 weeks ). I still have a set of valeo a4 ecode projector laying around, so I'll remove the lens and study that too.
I'll try the clear coat thing as last resort I suppose. I have can of acrylic clear coat from painting the side skirts on my A4. That should work out ok I hope. Thanks for the reply and input ell y!
Old 05-07-09, 12:39 PM
IronCobra
IronCobra's Avatar
Something to think about. While I was in San Antonio last weekend I was behind a GS430 (07-08) that had a great cut-off line. Mine is burry also and I thought that was how they all were until I saw this GS.... I'm confused now.
Old 05-07-09, 04:36 PM
rominl
exclusive matchup
rominl's Avatar
they all have the same headlights
Old 05-15-09, 07:51 AM
IronCobra
IronCobra's Avatar
Are you sure about this? I saw another GS460 last night and it's headlight output looked much more like a RX350 or a IS350 cutoff than my GS430 does.
Are you sure they didn't change the headlight from 07-09?
Old 05-15-09, 08:07 AM
IXI187IXI
IXI187IXI's Avatar
^^ i would assume so.
when i dropped my car off at the dealer for recalls, i had a IS250 and i notice the cut off line was so much smoother than my GS
Old 05-15-09, 08:21 AM
IronCobra
IronCobra's Avatar
It's really amazing how blurry my cut off is. So much so, that I would have assumed Lexus wouldn't have allowed this. IX187, can you take a picture of your cut off line tonight from about 50ft away? I'd like to see what yours looks like.
perhaps someone with a 08 or 09 model can do the same.
Thanks!
Old 05-15-09, 10:14 AM
rominl
exclusive matchup
rominl's Avatar
as far as i know the headlights have been the same
Quick Reply: blurry cutoff line
