Tips, Tricks, DIY's, & How-To's
Old 06-01-06, 09:56 PM
  #61
*wishlist*
*wishlist*'s Avatar
anyone know how to change the oil change warning light?
Old 06-01-06, 11:09 PM
  #62
john37
john37's Avatar
Does anyone know how to get rid of the tire pressure sensor warning?
Old 06-03-06, 10:22 AM
  #63
Eternity3G
Eternity3G's Avatar
Default ~attention!!!!~
***TO EVERYONE:***
Please use the "Title" section if you are posting a Tip, Trick, DIY, or How-To. Label what the purpose of the thread is so other fellow CL users can easily distinguish what the post is about and it is much easier to find the use of the thread. this also prevents others from "re-posting" similar posts...
Thank you all for your contributions and keep up the good work! Keep 'em comin' guys!
Old 06-04-06, 10:31 PM
  #64
thenod
thenod's Avatar
Default I can't seem to get it to work
Originally Posted by SGT
1. Make sure the car is in Park and the parking brake is disengaged before you start the car.
2. Start the engine.
3. Engage the parking brake.
4. Fully depress the brake pedal and then release.
5. Fully depress the brake pedal and then release.
6. Disengage the parking brake.
7. Fully depress and hold down the brake pedal.
8. Engage the parking brake, the disengage it (while holding down the brake pedal).
9. Engage the parking brake, the disengage it (while holding down the brake pedal).
10. Release the brake pedal.
11. Engage the parking brake.
12. Fully depress the brake pedal and then release.
13. Fully depress the brake pedal and then release.
* When the "Check VSC" icon is displayed in the multifunction display along with the "Trac-off" icon indicator, you'll know that you have successfully complete the procedure! Your car is transformed!
*** One the car is started you have 30 seconds to complete the process. With practice, the procedure can be completed in app. 15 seconds, unfortunately, must be repeated each time the car is switched off (all systems are returned back to normal).
I spent about an hour this morning trying to get this thing to work. on my 450h. I've tried it at least 50 times and still nothing. What am I doing wrong? I'm doing the entire sequence in way under 30 seconds. Any advice will greatly be appreciated.
Old 06-06-06, 05:58 PM
  #65
john37
john37's Avatar
Old 06-08-06, 04:10 AM
  #66
szilu
szilu's Avatar
Default nav and phone override
Hi there!
Does anyone have any idea why I can not enter the hidden menu where the override feature can be enabled? I've tried it in motion, stopped, engine shut, ignition on but nothing. I press the menu-volume-upleft-down left, upleft-down left corners and nothing happens.
I have a GS 300 manufactured in 8/2005.
Any advice would be appreciated.
thx
Old 06-08-06, 09:49 AM
  #67
Eternity3G
Eternity3G's Avatar
Default TPMS Sensor
I don't believe there is a permanent fix rather than actually installing the sensors onto the aftermarket wheels. You can either create a pilot hole and install a secondary valve-stem to fasten it or use the old-fashioned strap (I personally don't care for the strapping method).
Old 06-08-06, 09:51 AM
  #68
Eternity3G
Eternity3G's Avatar
Originally Posted by szilu
Hi there!
thx
??? weird ???
did you follow the intructions exactly? Sansei has a similar production date and his works... sometimes i have to repeat the process if i do it too fast... sorry not being very helpful...
Old 06-09-06, 05:39 AM
  #69
szilu
szilu's Avatar
Unhappy override menu
Originally Posted by Eternity3G
??? weird ???
As the process is not that complicated and I have tried it several times I think I did it right. I will try it slower (athough I was in no hurry before)...
Old 06-10-06, 03:53 PM
  #70
szilu
szilu's Avatar
have tried in slowmotion, moderate and quick but still nothing...
Old 06-10-06, 09:42 PM
  #71
Valet Park
Valet Park's Avatar
F Yeah, this is great stuff here. Definitely contribution worthy, thnx.
Old 06-11-06, 06:26 PM
  #72
Valet Park
Valet Park's Avatar
Default The seat belt mod won't cooperate.
I tried the initial instructions over 5 times then read through the entire thread and saw the amendment. Still nothing,here is what IM doing, is this right.
1. get in car
2. hit start butoon twice w/out brake
3. select trip B with (odo trip) button
4.push and hold (odo trip) for more than ten seconds
5. put on seat belt
Anyone that got this to work please let me know whatIm doing wrong.
Old 06-11-06, 06:49 PM
  #73
thenod
thenod's Avatar
That's VERY BIZARRE because I VERY EASILY override every single time i get into the car with ease. Shoot, my 8 year old even memorized the process and does it for me once in awhile.
Old 06-12-06, 01:53 PM
  #74
Eternity3G
Eternity3G's Avatar
1. get in car
5. put on seat belt
I revised it a little.. try it now..
Old 06-12-06, 03:18 PM
  #75
Valet Park
Valet Park's Avatar
Ok, just tried it again and nothing, I must be very slow. What about this, when I select the Odometer, you have to push it once more to hold ten seconds then the display changes to Trip A.
Or should I select ODO and hold? Im going to try that and see if that works.
Quick Reply: Tips, Tricks, DIY's, & How-To's
