Tips, Tricks, DIY's, & How-To's
Old 05-14-14, 08:49 AM
  #691
sjt0017
sjt0017's Avatar
Originally Posted by rustyd
Is there any way to program the mirrors so they don't move when you put the car in reverse? I think the motors on mine are going out, the drivers side doesn't go down at all and the passenger side does sometimes. Then when you put in drive, I always have to re-adjust the mirrors.
Rusty,
Put your car in reverse, then adjust the mirrors to where you want them while reversing. Then put the car in drive or park. Next time you put the car in reverse, it'll only move to memory from the last time you adjusted while in reverse. Also, when the motor sounds like it's trying to move the mirror but nothing happens, you might have your mirror popped out of place (usually happens when you get your car washed). Just adjust it (will hear pops) until it feels like it's back in place & everything should work as normal. Hope this helps.
Old 05-19-14, 05:41 PM
  #692
flipfoose
flipfoose's Avatar
Default is there a way to play dvds thru the navi in a 07 gs 350
After I eject the navi disc what do I do?
Old 06-17-14, 05:44 PM
  #693
artboy
7th Gear
artboy's Avatar
Do you know of a NAV system manual for GS350 2007?
Old 06-17-14, 08:17 PM
  #694
YaMomma
YaMomma's Avatar
Yes, I have a navigation manual that's bigger than the car manual lol. If you're looking for something specific all the information is online at lexus.com
https://secure.drivers.lexus.com/lex...nual-search.do
Old 06-18-14, 11:07 AM
  #695
willzGS350
willzGS350's Avatar
Originally Posted by Eternity3G
1) Press "Menu" button
2) Press "Volume" on the Nav Screen"
3) Press the "speaker" picture on the top left screen
4) Press the bottom left corner of the screen (it's blank, nothing there)
5) Repeat steps 3 & 4
6) A screen should now Appear w/ several functions
7) Find the "Override" button and hold until you hear a "beep"
8) The Override button letters should now be in black as the others are white
9) Press the Back button and you are ready to go!
*** Keep in mind this feature is required to be done everytime you start the vehicle. It will not retain this in memory ***
hey buddy i own a 2007 gs350 awd i have tried it over and over again and it does nothing any help or advice?
Old 07-29-14, 06:00 PM
  #696
Jamil
Jamil's Avatar
Hey guys, I think someone was asking how to stop the side view mirrors from going down when the car is in reverse.
I figured it out - open the console where you adjust the mirrors. You know you have to press L to adjust the left mirror and R to adjust the right, press the R once so the selections goes to the right and then press the R again. the light will turn off on which mirror is active and now the mirrors wont go down when in reverse.
Hope that works for everyone.
Old 12-28-15, 10:27 PM
  #697
Kashill
Kashill's Avatar
Wow! Lots of cool tips! Thank you.
Old 01-04-16, 11:44 AM
  #698
SergeyNWL
SergeyNWL's Avatar
Eternity3G Thank you for seat belt buzzer tip.
Old 01-05-16, 04:48 AM
  #699
burny
burny's Avatar
Those green lights on the L and R mirror buttons have to be off and the mirror won't adjust.
Old 05-20-17, 04:45 AM
  #700
aneidiaz
aneidiaz's Avatar
Does this procedure also work for getting to DRL/high beams as well or why I need to remove whole front bumper to actually get to the DRLs comfortably? Thank you!
Here's how to change the inner bulb (parking/driving light - whatever it's called) Keep in mind, the day-time running lights are acutally the high-beams running at a lower wattage. This mod only changes the color of the lights when the actual headlights are on.
1) Follow steps in previous "How-to" to remove engine covers.
2) Locate light socket housing. You can locate the mini-wedge 168 style bulb in the inner set of circle lights from the outside of the light and follow the bulb back to get to the socket. It's SUPER long.
3) Once you find the socket, twist to loosen and pull out.
4) Remove bulb and replace with new bulb (small wedge/168-style)
5) Re-insert socket and twist to tighten.
6) Replace engine cover and -Done-!
(Smoky effect is secret cancer stick trick.. do at your own risk)
Old 10-28-19, 11:15 PM
  #701
Ramos
Ramos's Avatar
Default What is the Part No. for the Right Engine Cover Screw rivet/clip
Help,
The Lexus dealer did not have the part and refused to give me the part number.
I tried going to Toyota but they needed the Lexus part no.
Attached is a picture from this forum showing the screw.
I have a 2010 Lexus GS350.
Thanks
Old 12-03-19, 09:57 AM
  #702
HotRod2
HotRod2's Avatar
Lightbulb Lower door molding repair
The lower door molding on front passenger side door of my son's GS430 had pulled loose. I tried repairing it using 3M double sided molding tape, that would hold for a month or two but would eventually come loose too. I decided to break the remaining tabs off the molding piece and repair it correctly. Once the molding was off, I cleaned all parts up using rubbing alcohol and glued the broken tabs back on using Clear Gorilla Glue and clamping them into place until they had cured. I then removed the white retainer clips by carefully breaking the tabs inside the door and removing the remainder of the tab from the door panel. I purchased new retainer tabs and placed them into the repaired tabs of the molding and placed 3M double sided molding tape on the two end tabs as it was originally. You need to check the spacing of the molding between the front and rear doors and adjusting the white tabs prior to inserting the assembly into the holes in the door. I'd guess the entire process took about an hour in total over a few days time to allow the glue to cure. Link and photos below.
https://www.amazon.com/gp/product/B016DC8U64/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B016DC8U64/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
Door without molding showing molding mounting hole.
Repaired tab with new retainer
Repaired tab with new retainer and 3M molding tape
New tabs from Amazon.com
pic of new tabs
Done....
Tee
04-27-19 06:42 PM
Tiggerr
General Classifieds
10-08-15 09:29 PM
5t341th
Performance
32
09-18-14 08:26 PM
7schulz
54
06-25-14 09:32 AM
anulex
GX - 1st Gen (2004-2009)
04-03-10 10:21 PM
Quick Reply: Tips, Tricks, DIY's, & How-To's
