Removal of driver seat headrest
Old 06-18-09, 04:24 PM
rominl
exclusive matchup
rominl's Avatar
actually the headrests ARE motorized.... but it goes up and down according to the seat position (try pulling your seat forward and backward and you will see the headrest move). but true that there is no SEPARATE button to adjust it
if you adjust your seat and then want to further adjust the headrest, you press on that button (look for the imprint) and adjust it
Old 06-19-09, 05:40 AM
The G Man
The G Man's Avatar
If the GS headrest is motorized, they should have put a power manual button there like the E class.
Old 06-19-09, 11:33 AM
rominl
exclusive matchup
rominl's Avatar
tell me about it. just like the mirror folding.
but for sure it moves together with the seat. that's why if you look at the passenger side, iirc, it's just like the traditional setup at the base of the poles
Old 11-19-10, 07:08 PM
CalCounsel
CalCounsel's Avatar
Anyone figure Out how to remove it? Diagram/pics and instructions?
Old 02-16-11, 11:24 AM
alwayzspeedin
alwayzspeedin's Avatar
bump i want to know i have headrest monitors ready to go in??????
Old 02-16-11, 12:35 PM
BinaryJay
BinaryJay's Avatar
Yep it moves by itself. I know this because I always set it back down to the lowest level and after I while I look at it and it's moved up again. :P
Old 01-04-12, 06:38 AM
jtrue28
jtrue28's Avatar
Bump. I need to remove the driver headrest and want to make sure I do it right while not breaking anything. TIA.
Old 01-04-12, 06:55 AM
lkapimp216
lkapimp216's Avatar
You fully extend the headrest and pull the post apart from one another and pull up its kinda tough that's how mine came out when I put my aftermarket ones in
Old 01-04-12, 07:24 AM
jtrue28
jtrue28's Avatar
But I also want to put it back, so as long as doing it that way is correct, thanks. I read in one thread where there may be a pin holding it and removing the seat panel is required.
Old 05-09-20, 05:04 PM
aznxenon
aznxenon's Avatar
Was looking for a way to remove my headrest and this was the first result on Google. However, there's no information on how to remove. For future references for others like me, it turns out it's held on by 2 pins, exactly the same as the LS460 as shown in the thread here. https://www.clublexus.com/forums/ls-...r-ls460-l.html
Just need to under 2 screws to remove the back panel, pull it off and remove the 2 pins and the headrest will slide right out. Be careful as the pin will fly away. Hope this will help someone in the future
ibgolfn
GX - 1st Gen (2004-2009)
09-02-18 04:51 AM
mikepgs350
06-26-18 02:16 PM
g0tem
RC - 1st Gen (2015-present)
04-13-18 02:22 AM
Ericspyder
01-29-18 03:43 PM
Fixman
12-16-16 09:03 AM
Quick Reply: Removal of driver seat headrest
