wind noise coming from sunroof
Old 04-28-05, 10:08 PM
frebay
frebay's Avatar
Default wind noise coming from sunroof
I have very slight wind noise coming through my sunroof but I only notice it when the solid screen is open, can someone else check if they are having the same problem? Is this just the nature of the beast, or should I take it back. It's sorta annoying while driving, but I don't want to be **** about it.
Old 04-28-05, 10:25 PM
chuckb
chuckb's Avatar
I don't have an 06, but both of my Lex have a little more wind noise when the sun shade is open. It's just because the glass is less insulated when the shade is pulled back. It shouldn't be too loud though.
Old 04-28-05, 11:39 PM
osx-addict
osx-addict's Avatar
I'll check mine tomorrow when I go to work, but I don't recall hearing wind noise when the roof is closed, but the cover is open.. I'll give some more info tomorrow..
Old 04-29-05, 06:45 AM
bigzip
bigzip's Avatar
I hear absolutely no wind noise coming from mine. Take it back, nothing's too **** if it doesn't seem just right.
I had to take mine back three times to get the radio fixed. The reception was bad and they finally found that the amplifier in the roof did not have a good connection to the antenna in the back window. This was after they replaced the radio which didn't correct the problem
Old 04-29-05, 09:27 AM
frebay
frebay's Avatar
i think everyone should take a drive w/ the sunshade cover open and the sunroof close...there will be very slight wind noise. it's very slight, but then again it's a lexus, so i'll be taking her back in.
Old 04-29-05, 09:38 AM
osx-addict
osx-addict's Avatar
I don't hear any in mine either.. I'd suggest taking it back for an adjustment as well..
Old 05-13-06, 09:57 PM
james1017
james1017's Avatar
I'm having same problem as you and that noise is driving me crazy. Did you take your car to the dealer yet?
Old 05-14-06, 05:59 AM
jwa
jwa's Avatar
I can also hear the slight wind noise when the speed is above 55mph. I ask my dealer about it, and the response was that it's fairly common on the 3GS. I test drove another new one to verify, and it performed similarly.
Old 05-14-06, 09:50 PM
ajcsanders
ajcsanders's Avatar
I think if you are concentrating on the sun roof you tend to notice the wind noise coming from it - and if you close the cover it goes away - but you have to listen carefully - it's certainly not intrusive IMHO. What annoys me about the sun roof is that after you close it, it squeaks over every uneven surface you encounter...and it doesn't seem to stop until the next time you take the car out...
Old 05-15-06, 09:18 AM
drck1000
drck1000's Avatar
I drove all around on Saturday with my sunroof open and I didn't hear anything out of the ordinary. In fact, I forgot it was even open when I got in the car this morning. I leave the house before sunrise and was surprised when sunlight came in from the sunroof (as I usually have it closed).
Old 06-25-06, 09:25 PM
james1017
james1017's Avatar
I'm having the same problem. Did you fix this problem?
Old 06-25-06, 09:48 PM
UAL
UAL's Avatar
No wind noise from there, but did have it coming from the rear quarter window on passenger side. The dealer replaced it as they found a broken seal.
Old 06-25-06, 11:07 PM
smakar@ufl
smakar@ufl's Avatar
Yeah, I totally noticed that on my car too. Its really annoying having the shade opened during the highway
Tmymck
NX - 1st Gen (2015-2021)
04-24-17 10:42 AM
nyr726
RX - 4th Gen (2016-2022)
08-03-16 10:33 AM
JMJS49
ES - 5th Gen (2007-2012)
12-18-14 10:54 AM
Irishman06
03-16-09 05:12 PM
satxrx
RX - 1st Gen (1999-2003)
12-16-01 06:20 PM
Quick Reply: wind noise coming from sunroof
