View Poll Results: What gas do you purchase for your car?
Premium Only - I need all the ponies!
215
74.65%
Midgrade Only - Not primo but better than regular
24
8.33%
Regular - It's all the same to me
32
11.11%
Depends - Sometimes I feel like a premium, sometimes I don't
17
5.90%
Voters: 288. You may not vote on this poll
Merged 3GS Fuel Threads - Is it OK to use REGULAR gas Instead of PREMIUM?
Old 02-25-13, 06:46 AM
  #271
ibidu1
ibidu1's Avatar
Originally Posted by bigblack06
Well I guess to each his own, as I will not change my ways just as you all will not change, even though we give supporting evidence. If you all feel that makes sense we shall leave at that!
What supporting evidence? Everything posted does not show a test of the GS350 with 87 vs 93oct. If you show me something, real world testing of the actually vehicle I will be the first to switch.
I may just have to do the test myself
Old 02-25-13, 07:19 AM
  #272
bigblack06
bigblack06's Avatar
Ok we are basing this off the article which there are a couple on the internet. You will not find any evidence on your exact vehicle that should be understandable. Your car falls in the same category of a performance engine car, which they clearly discuss if you want specifics than do the test I could care less. Like I said before you will say what you will to continue to use Regular as I will continue to use premium. Can't teach a dog new tricks!
Old 02-25-13, 08:01 PM
  #273
BAR | F1
BAR | F1's Avatar
You can't argue history, 80k+ miles on 87 octane without complaint. Sure, I lose a couple mpg's in mileage but driving habits have a greater affect.
Old 02-25-13, 09:24 PM
  #274
energie8
energie8's Avatar
@slimmsled You ain't paying for their gas, so st fu. Let other people buy what they want to buy, its an OPTION.
Old 01-27-15, 11:05 AM
  #275
sprtdsgnGS
sprtdsgnGS's Avatar
Default premium fuel vs regular - opinions?
I know this has been discussed before on this forum but with gas prices at new lows I figured now would be a good time to bring it up again. I always use premium only but was seriously considering going to regular.
Main question is do you think it's really bad for the engine or does it just affect performance slightly?
Old 01-27-15, 11:44 AM
  #276
TRD_Power
TRD_Power's Avatar
Just stick to premium. I test drove another GS460 before buying mine, and the owner had used only regular, so you could hear it pinging a little bit while going up hills. Also, it idled kind of rough. The car had 70k on it, and lord knows what else had been done in that time, but he did say he used 87/regular all the time. It's better for your car to use premium, and you really don't save THAT much by switching. Anyways, that's my .02!
Old 01-27-15, 12:05 PM
  #277
pman6
pman6's Avatar
you save $3.xx per tank. Does that break the bank?
Old 01-27-15, 02:26 PM
  #278
Gotcha350
Gotcha350's Avatar
I've seen damage from using lower than suggested octane rating...PID can do damage...I had a friend that lived in Atlanta that drove an Infiniti I35 and he used regular it used to ping like crazy going up a hill or when he tired to pass people. He had to replace the head gaskets and he had damage to the upper cylinder and some valves from the higher exhaust temps....so for me...i'll continue to use premium...and i'll leave plenty of regular for those who want to use that.
Old 01-27-15, 03:16 PM
  #279
LoveThatV8
LoveThatV8's Avatar
I was a poor college student with a NEW tundra back in 2004 and so I stuck 87 in the tank and it ran like shat... It burned quicker too and defeated the purpose of putting gas money using 87. Never will go back, similar concept when I was curious sticking race gas 101 in the tank... Took forever to burn and more power came from it. Using 91 is our sweet spot.
Old 01-27-15, 04:28 PM
  #280
worker
worker's Avatar
I try 2 tanks of premium, my gs430 didn't like it. Feels like it was going to stall. When that 2nd tank was running low, I put in regular and it was happy again.
Old 01-27-15, 05:14 PM
  #281
TRD_Power
TRD_Power's Avatar
This sounds a bit odd The car shouldn't feel like it's going to stall, especially with premium. Anyways, glad it works fine with regular!
Old 01-27-15, 05:29 PM
  #282
Gotcha350
Gotcha350's Avatar
Probably because the ECM had kept the timing retarded for so long that combustion was late...lol
Old 01-27-15, 07:42 PM
  #283
worker
worker's Avatar
That's what I thought too, so give it 2nd tank. It should readjust by than but it reacts just the same.
I'm not buying into the "premium is better" but give it a try to see how it's different. The result wasn't good. End of that experiment.
Old 01-28-15, 12:20 AM
  #284
pman6
pman6's Avatar
disconnect the battery to reset the ecu. Should be clean slate for use with premium gas.
If you don't mind the horsepower drop, keep using regular.
Old 01-28-15, 12:46 AM
  #285
mr. tetsuo
mr. tetsuo's Avatar
im kind of surprised anyone would put in anything but premium
Quick Reply: Merged 3GS Fuel Threads - Is it OK to use REGULAR gas Instead of PREMIUM?
