remove pin stripe
Old 10-20-03, 07:34 PM
martialart
martialart's Avatar
Default remove pin stripe
does anyone know how to remove the pin striping on a lex? i put tape over it then pulled it off and it worked alittle bit but not that grate. any suggestions would help. thanks
Old 10-20-03, 07:52 PM
ChuH
ChuH's Avatar
Cool
Use a hair drier to heat up soften the pin strip. Use your finger nail to gently remove the pin strip and heat it as you pull the pin strip off. To clean any residue you can use WD-40 and a soft towel to wipe it clean then wash your car afterward.
Chu...
Old 10-20-03, 09:39 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,117 Likes on 1,292 Posts
Here are a couple of good threads I found using the search feature (hint ) using the kewords 'remove pin stripe' and 'pinstripe remove' that should help as well.
You'll need to figure out whether your pinstripe is a decal type (like mine was) which just peeled right off like an old sunburn, or a painted-on type which takes a little more work.
https://www.clublexus.com/forums/sho...ove+pin+stripe
https://www.clublexus.com/forums/sho...nstripe+remove
Old 10-21-03, 06:21 AM
martialart
martialart's Avatar
thanks for the help i will try it and let you know how it comes out.
truenoboy
01-27-09 07:37 PM
ekrebs
Performance & Maintenance
15
11-20-08 09:30 PM
habitat
Automotive Care & Detailing
10-31-07 04:09 PM
hapaboy
03-15-07 12:07 AM
Quick Reply: remove pin stripe
