Cool "hidden" features about the GS that are not very known
Old 07-26-03, 06:47 AM
  #31
SeaCruiser
SeaCruiser's Avatar
Hello Hameed
I just returned to this thread to make an inquiry about this same subject. I consider myself "mechanically impaired" and I was able to find the filter. (Thanks Drew) There is a panel below the CD changer. It measures 10 1/2 " X 2". It pulls out. Beneath it there is another panel. It has two grippers that allows you to slip it out. Then the filter slides out. Oh what a mess it was. I found leaves and thick dust. My question is are there replacement filters available? My Lexus dealer is over an hour away. I vacuumed the filter but I would feel better with a replacement.
Tip.. there are arrows on the panels to assist you in replacing them properly.
Gosh I learn so much stopping by this site!
Sea..
Old 07-26-03, 07:43 AM
  #32
DrewGS4
DrewGS4's Avatar
Hey guys, no problem...glad to help other CL members.
I know a lexus tech and he says that they rarely replace the AC filter but the customer is always charged for it. This is the biggest scam going on .....not just with lexus but with other dealers as well.
When in doubt change it yourself....nobody is going to do a better job than you the "owner".
Even if you try catching them...and check later....they will just say they forgot and than will truly replace the filter.
Makes you wonder what else the dealers say they will do but in reality do not?
Old 07-29-03, 10:43 AM
  #33
LarryF
LarryF's Avatar
My dealer replaced my filter at 30,000 and charged me around $50 for the new one! OUCH!! I remember seeing a thread on this site a year ago about making a replacement filter yourself by cutting down a larger home air conditioner filter. Much cheaper than the factory replacement.
Old 07-31-03, 11:16 AM
  #34
LarryF
LarryF's Avatar
Just remembered another A/C filter story -- a guy I work with who also has a GS told me that he was getting a foul smell in the cabin, and he removed the A/C filter and found a dead mouse in it. YUK
Old 10-01-03, 07:23 AM
  #35
Lubs
Lubs's Avatar
Originally posted by DrewGS4
4. In the glove box, you can get to the Air conditioner filter and clean it out. You can remove the panel by pulling it straight out and than slide out the A/C filter. I could not believe how dirty and filthy my filter was and I was breathing all that ****** when the AC was on.
5. When giving the car to a valet, you can insert the key into the lock and lock it. But you can also lock it without the key. Just push the lock in and the trunk locks itself. To unlock it you would need to use the key.
Originally posted by DaveGS4
11) There are two 'stops' for windshield wipers on the 2nd gen GS, a winter / ice setting and a regular lower setting. If your wipers on on the winter setting they sit way up high on the window and don't tuck behind the cowl. Just push them down hard and they'll 'pop' past the winter stop into the normal one. Looks much better.
RE: 4) My A/C filter was clogged up with leaves, dust, dirt, my old pet hamster, you name it. It feels good to know it's much cleaner now. To get at it, I took off a black piece in the back of my glove box, then another piece in front of the filter, and then slid out the filter.
RE: 5) I don't understand this one, can someone elaborate?
RE: 11) Having the wipers in winter mode bothered me, but I had figured that's just how they were. Pushing them down not only gives a better view of the road, but the view of my car is that much sexier. Great tip.
Nice thread guys.
Old 10-01-03, 07:27 AM
  #36
Hameed
EV ftw!!!
Hameed's Avatar
Default Re: Cool "Hidden" features about the GS that are not very obvious
3. Steering wheel can be lowered even more by holding the down button for about 6 seconds followed by by a couple more pushes which will bring the steering wheel even lower.
To move the steering wheel and extra 1/2in to 1inch in any directions....click the button 8 times in the direction you want it to move it
Has anyone else noticed that you cannot save this last movement of the steering wheel (the last movement it makes down after pushing the button 8 times) in the memory buttons?
Old 10-01-03, 09:14 AM
  #37
TerryTCL
TerryTCL's Avatar
Nice thread guys.
#5 - Drew is talking about the lock cylinder that located above the trunk release and fuel door release on the lower left of the dash...
the lock cylinder can be pushed in to prevent anyone from using the electronic switches to open the trunk or fuel door... in order to release this lock, you need your master key... just turn and the lock cylinder will push back up to the oringinal unlocked position.
Old 10-01-03, 09:26 AM
  #38
cjnmel
cjnmel's Avatar
Question does this???
apply only on the 2nd Generation GS's????
Old 10-01-03, 09:43 AM
  #39
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
Default Re: does this???
Yes, that's what this particular forum is.... 2nd Gen GS
BUT it's worth trying them on your first gen GS as well , some of them will work. I believe some of the first gen guys started a similar thread a while back. Edit, found it. Click here for first gen hidden features thread
Old 10-01-03, 10:19 AM
  #40
jcramair1
jcramair1's Avatar
Excellent stuff thanks for sharing the info.
JOhn
Old 10-01-03, 10:56 AM
  #41
TwentyTen
TwentyTen's Avatar
Hey Drew -This should save you 50 dollars on a hepa filter:
http://lexusmodz.netfirms.com/GS_DIY/hepa_filter/
Thanks BananaGS!!!!
Old 10-01-03, 02:08 PM
  #42
DrewGS4
DrewGS4's Avatar
Darius, looking good and nice DIY mod.
I am just pleased to see that this thread has helped out so many other members
Old 10-02-03, 08:57 AM
  #43
Bdragon007
Bdragon007's Avatar
Well this is not really a hidden feature, but for me it's pretty useful trick when paralell parking. Since i'm the only one who drive my car, i used only one memory setting for the seat and the other i used it to adjust the side view mirrors to see the rim, so i woudn't get it mess up when i paralell park.
Dan
Old 10-02-03, 08:59 AM
  #44
Hameed
EV ftw!!!
Hameed's Avatar
Old 10-02-03, 11:22 AM
  #45
DrewGS4
DrewGS4's Avatar
Hey Hameed,
I think you are right, the final move of the steering wheel does not get saved in memory. It is only good as long as the car is on. Might be a c-best fix but I'm not sure.
Quick Reply: Cool "hidden" features about the GS that are not very known
