Cool "hidden" features about the GS that are not very known
Old 09-16-06, 12:55 AM
  #196
blue99GS4
blue99GS4's Avatar
Default Sub woofer mod
It worked for me. I set F and R at 5, P1 at 2. There's a big difference compared to stock setting. I'm still not sure what are the other features (P2, L, etc...) for? BTW, I have a 99 GS400 with the Pioneer unit. Great mod.
Old 09-20-06, 07:07 AM
  #197
nikko2jzge
nikko2jzge's Avatar
will this audio mod not work on an 01. Got the p190 display, but no adjustments to make any sound changes.
Old 09-25-06, 08:30 AM
  #198
mikevanle
mikevanle's Avatar
Originally Posted by TerryTCL
#5 - Drew is talking about the lock cylinder that located above the trunk release and fuel door release on the lower left of the dash...
the lock cylinder can be pushed in to prevent anyone from using the electronic switches to open the trunk or fuel door... in order to release this lock, you need your master key... just turn and the lock cylinder will push back up to the oringinal unlocked position.
I tried this lock cyclinder thing, and was still able to open the trunk via the trunk switch (inside the car) and the one on the remote.
Again, what's the purpose of this?
Old 09-29-06, 08:39 AM
  #199
CRSO
CRSO's Avatar
Default i just wanted to
Originally Posted by jesod
You don't have 1 and 6 buttons for radio presets? If it's nav you have to follow the procedures mentioned in the posts above. If you don't have nav. push the 1 and the 6 on the radio presets and push CD 4 times release everything once you see P190 and then hold the AM until Audio comes up, then adjust according to suggestions in previous posts.
confirm that this does not work for the nakamichi on a 98?
Old 09-29-06, 10:25 AM
  #200
mikeydread
mikeydread's Avatar
Default lights
about the headlights thing, I know auto turns the light on when its dark and off when its bright, but when you park do you then have to manually turn the lights off from the switch or does it turn off after a certain time period, because i left my lights on for about 2 minutes and it never turned off so i had to do it before it killed the battery, will be trying the 2 touch of the lock button later but i think i have tried it before and not have it work, do you do it in the auto position or in the regular on position?
Old 09-29-06, 10:45 AM
  #201
mikeydread
mikeydread's Avatar
Well, I will be joining the list of people who's lights does not turn off when you double press the lock button the remote, and i can't try it on auto now because, well, its daytime, so i will try it later.
Old 09-29-06, 10:58 AM
  #202
Billh2
Billh2's Avatar
Pressing lock twice on my remote will trun off the lights, UNLESS the trunk is open. Then they stay on until I close it. Found this out the hard way.
Old 09-29-06, 12:55 PM
  #203
mikevanle
mikevanle's Avatar
Well my headlights will only turn on in the "auto" position I think a relay a broken somewhere.
Anyways, yes it does turn off when I hit lock twice in a row.
Old 09-29-06, 05:10 PM
  #204
Adam2562
Adam2562's Avatar
with the navi.. id ont thinku can adjust ur bass at all with this mod thingy besides using the normal function audio control button
Old 09-29-06, 09:50 PM
  #205
CRSO
CRSO's Avatar
Default ...
Are there any audio adjustments for the Nakamichi Head Unit on a 98 GS or only the lexus branded one?
Old 09-30-06, 11:02 PM
  #206
David1969
David1969's Avatar
I've searched around and couldn't find this one:
When i'm taking off in the car and either put the car in reverse or drive, i'd like to have all the doors lock immediately. Is this possible? I didn't see it in the c-best list.
Old 10-01-06, 10:36 PM
  #207
bandgap112
bandgap112's Avatar
My '02 GS430 Nav. does that. It locks all doors when I shift to Drive or Reverse. It was like that when I bought the car. I thought it's a standard feature for the GS.
Bandgap
Old 10-02-06, 08:09 AM
  #208
mikevanle
mikevanle's Avatar
It's not a "standard", it's a option really. You need the dealership to program it in.
Old 10-02-06, 11:14 AM
  #209
tmeg
tmeg's Avatar
But it is dependent on the "localization" of the car. I went to the dealer and asked for that. They could only enable the function to open the doors, when putting the gear into P position. Closing the doors seems to be a no-go in European version cars (Germany), the reprograming failed.
Old 10-02-06, 05:02 PM
  #210
mvallido
mvallido's Avatar
4. In the glove box, you can get to the Air conditioner filter and clean it out. You can remove the panel by pulling it straight out and than slide out the A/C filter. I could not believe how dirty and filthy my filter was and I was breathing all that ****** when the AC was on.
I have a CD changer in the glove box. How do I get to the AC filter?
Quick Reply: Cool "hidden" features about the GS that are not very known
