Car "ran out of gas"..but took only 12 gallons to fill?
99 gs400. Was driving home on I-10 yesterday when the car started to sputter, tank read between 1/4 and 1/2 remaining. Thankfully I was close to an exit and so I sputtered in "on fumes" to the gas station just barely making it. Filled up and noticed it only took 12 gallons, wtf? Car ran 100% fine after that.
This is my gf's car, and she said it did the same thing when she first got it @ 1/4 tank, so she always kept it over that. I just figured it was an inaccurate gauge reading, so never worried about it. But "running out of gas" when there is ~7 gallons left(nearly half the tank)....something else is up.
Bad fuel pump? Clogged fuel filter?
Have a look at the link below. It sounds like your fuel gauge sender is bad. I found the diagram to test the sender before. I'll see if I can find it and add it here.
https://www.clublexus.com/forums/gs-second-generation/593459-00-gs300-fuel-pump-issue-need-some-guidance.html
Even if the fuel gauge sender is broken, or the float is broken..etc That wouldnt account for the car not running when there is still 7 gallons left in the car right?. I see from the link posted above that there is a siphon tube that connects both parts of the tank, I think this might be the culprit as I dont see what else would cause this specific problem.
Thanks for the replies.
Anyone have the exploded view of the gas tank? Just want to see what the humps/siphon tube look like before diagnosing anything else. The sewell link no longer works.
I mean, something like this is REALLY unlikely, but it's possible...
http://www.e30tech.com/forum/showthread.php?t=28865
TL;DR: Guy buys E30 M3, fills the tank on "empty" and it doesn't take as many gallons as it should. Turns out there's a hidden pocket cut into the gas tank for drug smuggling purposes.
Definitely not a sender issue, evidently these guys dont know how big our tanks are. You are correct. Last week I was just under a quarter tank and I put 11.5 gallons in and it wasnt full yet. You're on the right track with diagnosing, is this the blow up you're looking for?
I found this while searching for a vacuum hose diagram. It states on how the suction from the passenger side gas should work. Though it doesn't state if the guy fixed his problem or not.
http://www.justanswer.com/lexus/869t5-lexus-gs-400-99-gs400-need-replace-valve.html#re.v/173/
Not exactly sure if this is the solution but going to try it tomorrow. I believe in theory its just like changing your brakes. Just like the brake system the fuel system is pressurized. I have a 98' and a 00' GS300 and both have had this same problem, been dealing with this for months. I check back on this thread periodically to see if anyone has found a fix. I believe there's a purge valve on pretty much all fuel systems, the same way you would have to bleed your brake lines to release any air in the system I think once you open the fuel system we have to purge it to get the air out the lines. Gonna attempt it tomorrow, put a small gas tank in the trunk and try to take it down to E. I'll update once I get there.
Mine is off by an eighth of a tank lol. I've run out of gas twice thinking I had enough to get to the station.....it's wifey's car, and she has a knack of getting to the house with just enough fuel. I always pass the first station because the gs likes mobile lol....and I've paid twice. Now I tell her to fill up just under a quarter tank. I'm not gonna fix it unless it gets worse....the car's a 98. Actually considering a 2012 300 5.7 When we hit 150k
qewani1
04-14-09 03:09 PM
