2002 gs430 ac problem need help
Old 05-15-15, 09:14 AM
billycocky
billycocky's Avatar
Question 2002 gs430 ac problem need help
so my compressor clicks on , i used the ac machine to recharge it 3 times, then changed expansion valve and dryer on side of condenser recharged and still not getting cold air:** plez help....i also checked for leaks no leaks relays and switch work because the compressor clicks on
Old 05-15-15, 09:37 AM
billycocky
billycocky's Avatar
please help its gonna be 90 and raining tomorrow
Old 05-17-15, 03:49 PM
lvfstde
lvfstde's Avatar
do u here click from inside the car?
Old 05-17-15, 09:04 PM
billycocky
billycocky's Avatar
Yes when I turn on Ac u can here it click on and I can see it spinning under the hood
Old 05-18-15, 06:07 PM
JJaySilver
JJaySilver's Avatar
Did you at least flush out the lines? If it was dirty, you will need to replace your drier because its been contaminated again; that crap is coming from the compressor being circulated throughout the A/C system, if heavy dirt came out, your compressor could be on its way out. How's your A/C condenser, is it dirty and/or has damaged fins? If so, replace that thing, its the most important part of your A/C system.
Old 05-18-15, 06:38 PM
marshun
marshun's Avatar
you used a vacuum? so it had gauges right? what were the readings?
Old 05-18-15, 06:51 PM
JJaySilver
JJaySilver's Avatar
Yeah, I forgot to ask about the high and low pressure readings. What do they read?
Old 05-19-15, 10:19 AM
billycocky
billycocky's Avatar
60 high 55 low
Old 05-19-15, 10:21 AM
billycocky
billycocky's Avatar
i ordered a new compressor yesterday guess ill find out if its that on the 28th
Old 05-21-15, 09:30 AM
billycocky
billycocky's Avatar
Guess it was the compressor put a new one in and man its too cold now lol....
Old 05-22-15, 08:17 PM
JJaySilver
JJaySilver's Avatar
The reading for the high side a really low, should be a lot higher than that. The low is good depending on the temps, because the psi fluctuates with the temps. But sense you change your compressor, that could be a reason why. Was those numbers read with the engine running? If you can, what's your gauge reading with the new compressor?
Glad to know its working again though, its a great feeling, but hopefully you flushed your lines and replaced your drier if there was contaminants in the lines, becuse dirty lines will mess up the drier and kill your new compressor. I learned my lesson twice. Lol!
monkey92
06-22-16 02:37 PM
chuck77083
08-09-14 07:41 PM
jami1
15
06-19-13 04:28 PM
yamiken1
GS - 1st Gen (1993-1997)
07-08-12 11:08 PM
evileagle
SC- 1st Gen (1992-2000)
05-09-10 10:01 AM
Quick Reply: 2002 gs430 ac problem need help
