Fog light LED DRLs
Old 05-21-15, 12:38 PM
budgetvip
budgetvip's Avatar
How did you guys wire these in? Just tap into a 12v source that's only on with the key?
Old 05-21-15, 06:27 PM
lostape45
lostape45's Avatar
Yes. Unfortunately I couldn't find any that were only on with the key under the hood so I tapped into the "Gauge" fuse in the drivers side fuse panel. Just use the hot from fuse and ground the negative to the battery and you're set.
Old 05-21-15, 07:44 PM
budgetvip
budgetvip's Avatar
The 20 amp washer fuse is only on with the key in the on position also did you use any resistors?
Old 05-21-15, 08:43 PM
lostape45
lostape45's Avatar
Yes that fuse will work too. I didn't use any resistors
Old 05-23-15, 07:15 AM
Mcon
Mcon's Avatar
Guys, guys, guys.... Check this website, to turn ON and OFF your fog light from the original switch. You can turn ON and OFF with only your parking light ON. Is very easy to do. Check please. bananags.grantham-international.com
Old 05-23-15, 09:19 PM
budgetvip
budgetvip's Avatar
I've already done that but when you aren't using the factory harness you can't tie it in that easy
Old 05-26-15, 06:10 PM
seivonecsu
seivonecsu's Avatar
Old 05-26-15, 07:37 PM
lostape45
lostape45's Avatar
Approval from the man himself, I dig!
Old 05-28-15, 03:22 PM
Mcon
Mcon's Avatar
Great job, bro..
Old 06-09-15, 03:40 PM
SenecaRex
SenecaRex's Avatar
Maybe you should ground it to a ground instead of Neg terminal?
Regardless, looks great. Planning on doing something similar.
Old 06-09-15, 06:50 PM
lostape45
lostape45's Avatar
Default Fog light LED DRLs
I honestly never thought of that. I'll try that soon to see how it works. Thanks! You'll have to show me what you come up with.
NudleBoy
CT 200h Model (2011-2017)
32
10-29-22 06:22 PM
jaym74526
RX - 3rd Gen (2010-2015)
12
06-19-21 03:48 PM
Sean
IS F (2008-2014)
13
01-19-15 07:12 AM
Rachelleee
09-21-13 11:41 AM
illtech
06-01-08 01:08 AM
Quick Reply: Fog light LED DRLs
