99 GS400 engine, what CAN cause limp mode?
Old 04-10-15, 06:49 AM
nxtproject
nxtproject's Avatar
Default 99 GS400 engine, what CAN cause limp mode?
Im swapping a vvti 1uz into my S14 and using the stock ecu (i know, please don't ask why i didnt just go with programmable ecu).
As such, i gutted the auto trans and left all of the solenoids hooked up in an effort to avoid those codes.
From what i've read, i will still throw a Vehicle Speed Sensor code as that sensor isnt part of the main harness that came with my engine/trans (trans was tossed in favor of 350z CD009 trans).
So im only wondering what codes cause a mandatory limp mode. Emissions equipment codes (vent valve? although im sure i can figure out a way to integrate that function) abs codes? (not familiar with the ecu enough to know if that is expecting to see ABS data) trans codes? (have no clue which ones will pop up as the swap isnt finished yet, but its getting close!)
Old 04-16-15, 09:13 AM
nxtproject
nxtproject's Avatar
no thoughts on this?
btw, the immobilizer has been bypassed internally inside the ecu.
Old 11-07-19, 01:29 AM
Firefoxray
Firefoxray's Avatar
Default Did you ever find out what causes it?
Hey, I have a friend with a 1uz in his S14 running stock ecu, I know this was a while ago, but do you know what exactly caused your limp mode? We've tried everything but we can't find out why. Trans is a cd009.
Old 11-07-19, 12:43 PM
k7q
k7q's Avatar
Bad Knock sensors can cause limp mode
Old 11-08-19, 05:15 PM
EuroWill
EuroWill's Avatar
Can you post a list of the codes that are present?
Old 11-09-19, 03:31 AM
Arussto
Arussto's Avatar
Default How to bypass imm?
Is it possible to bypass immobilizer in ecu?
How difficult?
What is involved?
Old 11-09-19, 07:44 AM
Firefoxray
Firefoxray's Avatar
How difficult?
What is involved?
Our ECU was bypassed by some guy in Russia, I don't remember exactly who, but here is a picture of the ECU with some info if you can see.
Arussto (11-09-19)
Old 11-09-19, 08:29 AM
Arussto
Arussto's Avatar
Wow!
At least we who did not know now know that it can be done at some level and posdibly simply bt an electronics tech.
I always thoughtvthere must be a way😁
Thanks forvhhe info.
Russ
Old 11-09-19, 04:56 PM
TrueGS300
TrueGS300's Avatar
Did you ever check for codes? In my experience limp mode is usually always throttle related. Sometimes it just needs a good clean and reset. Did you happen to replace the battery recently or have it disconnected? This will lose learned memory and if the throttle is dirty, it wont run right after a battery disconnect.
gr8wyt
10-16-16 02:23 AM
Mtdave2
13
09-18-15 11:02 PM
Nosebleed
SC- 1st Gen (1992-2000)
05-31-13 04:36 PM
ScDre
Performance & Maintenance
07-09-12 02:47 PM
TheRonTom3
09-19-09 06:14 AM
Quick Reply: 99 GS400 engine, what CAN cause limp mode?
