2000 GS300 misfire in cyl 1,3,5
Old 03-10-15, 03:38 PM
troutman56
troutman56's Avatar
Default 2000 GS300 misfire in cyl 1,3,5
Today my wife calls me at work saying the car is shaking bad when at idle. I meet her up after work, start the car and notice the shake. No unusual sounds but I did notice a subtle, different, odd exhaust smell. I drive the car home and notice no huge change in performance other than some slight hesitation from the line. The engine seems to smooth out as the RPMs increase. I also notice the check engine light blinking so i swing into Autozone and they scan it and tell me misfires are happening in 1,3,5. I did not get the codes printed which I should have but from google searching this could be plugs, coil packs, injectors.. Among other things. I did read that cylinders 1,3,5 are on separate coil packs so that may eliminate the potential for that problem. I also need to have an o2 sensor replaced but thats been needing that for 6 months and I have never had issues with bad o2 sensors causing issues on other vehicles.... Please advise.
Old 03-11-15, 04:25 PM
Mr Jokster
Mr Jokster's Avatar
Codes would help a lot in diagnosing. Many things can cause a misfire.
Old 03-11-15, 09:02 PM
StanTycoon
StanTycoon's Avatar
it could be your oil valve control or bad o2 sensors
Old 03-12-15, 10:12 AM
DriftOner
DriftOner's Avatar
I had a similar problem and it turned out to be a combination of a couple things. I had a leak at the back of the plug valley and coolant was filling the spark plug holes. Once that was fixed the misfire stopped but it would shake at idle still. That was fixed by replacing the oil control valve. Now it's good as new and you'd never guess it has 255k miles
Old 03-12-15, 12:25 PM
troutman56
troutman56's Avatar
I was thinking o2 sensors. My dad had this problem when he had the car and while he doesn't remember specifics, he does recall the o2 sensors being replaced. I am replacing bank 1, senor 2 tonight which is what initially threw a code. I will also pull, inspect, and clean the others. If that doesn't work I will get the codes and see if its deeper than this..
Old 03-12-15, 09:20 PM
geeznuts
geeznuts's Avatar
What's the mileage? Maybe timing belt jumped a tooth?
Old 03-13-15, 10:21 AM
troutman56
troutman56's Avatar
Just had the timing belt done a couple months ago.. Have run a few thousand miles since then.
Old 01-11-21, 02:01 PM
is300eli
is300eli's Avatar
Doesnt the oil control valve give a code though? Asking because im having the same issues today and wanted to know if its just the wires or the ocv since the misfire is mainly on idle.
M9000
RX - 1st Gen (1999-2003)
15
10-25-21 10:03 AM
ancdmd
04-13-16 07:34 AM
troutman56
03-14-15 06:08 PM
pyrosharp
03-04-14 05:56 PM
BRAKATK
GS - 1st Gen (1993-1997)
10-04-06 05:53 PM
Quick Reply: 2000 GS300 misfire in cyl 1,3,5
