Wheel Spacer Question
I have a set of 18" wheels that are 8" wide with a 40mm offset, and my rear wheels are way too tucked for my taste still. I think the front looks perfect tbh, so I'm just looking for the perfect size wheel spacer to match the front.
What size wheel spacer should I get and what brand should I go with? Also what kind of design is the safest? Bolt on or the ones with longer bolts that you replace the stock studs with?
Oh ok. If im seeing correctly (im on phone). One has studs separate the other has studs on them. The one with studs with studs on them are their because the spacer is so big that its unsafe to have a very long stud as opposed to those using the stock studs to bolt the spacer on THEN bolting to the wheel. Basically, once you get to a certain size, they automatically have studs attached. You wont find attached studs on a 10mm spacer ya know what i mean.
BTW, you can get the same exact ones on ebay for much cheaper with warranty too. I believe I only paid like $80 shipped for my H&R's Or did I get Ichiba LoL
