P1651 fault (VSV) Vacuum switching valve
Old 03-03-15, 11:01 AM
RichS11
RichS11's Avatar
Default P1651 fault (VSV) Vacuum switching valve
Hi guys,
I have searched and I know what this code is, I know what's causing it and what the item is that needs replacing, my problem is this.....
What is the part number?
I have found what I need on RockAuto, but it states that this part is for American and Canadian vehicles. I have emailed them to find out if this item is vehicle specific, but I cannot see why they would use a different part for different markets.
If anybody has some information that would be great. I know this is a 4 to 6 hour job, but I can do it at home and I'll replace the gaskets that I remove, mainly throttle body and inlet manifold. I just want to be able to pin down the part number so I can get it ordered.
Thanks.
Old 03-03-15, 12:37 PM
FrankT
FrankT's Avatar
ACIS Switch Valve 25860-62010
To verify part number should be printed on the VSV itself.
I don't know what motor you are referencing, but 4 to 6 hour seams a bit much...
Old 03-03-15, 12:42 PM
RichS11
RichS11's Avatar
Hi Frank,
I thought the time seemed too much but that's what most people online were saying it took Lexus to fit. I haven't got the item off the car yet and trying to find a part number in the UK is a joke, you'd think Lexus employees had signed an official secrets act!
The car runs well and I need to use her so I cannot take the TB and the inlet manifold off just to check the part number. That may be my only resort but I've posted this on a UK forum too, so fingers crossed I get lucky!
Thanks dude.
Old 03-03-15, 01:02 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
where is the valve located exactly?
Old 03-03-15, 01:05 PM
RichS11
RichS11's Avatar
I am trying to upload a pdf file. It shows you where it is, but basically it's under the inlet manifold.
COMP.PDF
It's on page 3 on the above pdf.
Old 03-03-15, 01:07 PM
tmf2004
tmf2004's Avatar
oh man its under the manifold?
Old 03-03-15, 01:14 PM
RichS11
RichS11's Avatar
Yes sir. Which makes finding the part number a pain in the ****!!
I may bite the bullet and buy the US part and fit it. I cannot see it being different, but it's annoying that I cannot be 100% sure!
Old 03-03-15, 01:53 PM
RichS11
RichS11's Avatar
Think I found the European part number 25860-50121
Old 03-03-15, 03:28 PM
FrankT
FrankT's Avatar
The intake come off as one complete assembly, no need to unbolt anything but the lower intake to cylinder head.
In the picture you can see your VSV
Old 03-03-15, 03:33 PM
RichS11
RichS11's Avatar
Frank, thank you so much dude. It seams as though we had a different part number over here, but at least you've confirmed that it is the part I've been looking for. Thanks!
*Edit* So you left the throttle body on too?
Old 03-03-15, 03:45 PM
FrankT
FrankT's Avatar
You can even leave the fuel line and coolant lines hooked up. All that needs to be done is lift the intake high enough. Intake gaskets will be in very good shape and you my choose to reuse them.
If you wish to completely remove the intake, this opens up a perfect opportunity to refurbish your starter with new contacts.
Good luck
Old 03-03-15, 03:58 PM
RichS11
RichS11's Avatar
Thanks Frank. I'll look into my options and see what else I can do. I may just change the VSV for now and the gasket, all depends on funds. Spent a lot this month and it's only the 3rd haha.
Old 03-03-15, 04:24 PM
burny
burny's Avatar
what year ride you sportin dood?
Old 03-03-15, 04:27 PM
RichS11
RichS11's Avatar
2002 buddy.
Old 03-03-15, 06:11 PM
tmf2004
tmf2004's Avatar
DIY rich....
Quick Reply: P1651 fault (VSV) Vacuum switching valve
