!!!Question for the GTE swapped guys!!!
Old 02-28-15, 08:44 AM
Miami-SC
Miami-SC's Avatar
Default !!!Question for the GTE swapped guys!!!
Especially the big power guys....how the hell do you keep track of your fuel level??? I have looked and no direct solution for me. When I got mine the previous owner said when it gets close to 200 miles, it's time to fill up, which sucks, bc all I have is BPU and TTC. Is there a solution I don't know about? Or some aftermarket part? Thank you in advance.
Old 02-28-15, 06:50 PM
TTurboPimp
TTurboPimp's Avatar
I assume you are talking about your fuel gauge level not reading right? If so, on mine, I always fill up when I get down around 1/4 tank. I can definitely go below that, but its not worth rolling the dice at that point. Im running E85 with close to 800rwhp, the last thing I want to do is run lean.
Old 03-01-15, 07:17 PM
Miami-SC
Miami-SC's Avatar
Yes I am.....that doesn't sound too bad, thanks!
Old 03-04-15, 07:14 PM
TTurboPimp
TTurboPimp's Avatar
Yeah, it's not a big deal.....just think of 1/4 as E and go from there.
Old 03-05-15, 12:24 PM
KeyKeeper
KeyKeeper's Avatar
Forgive my ignorance, but why cant an aristo sending unit be used?
Old 03-05-15, 11:52 PM
iToaster
iToaster's Avatar
It can, but it won't fix the fuel level issue. More specifically, the fuel level issue is caused by the Aristo GTE ECU being mismatched to the GS gauge cluster. In the GS under normal operation the fuel level is based on fuel economy data calculated by the gauge cluster instead of measured directly from the tank as a means of preventing the needle from fluctuating in an "unrefined" fashion. The ECU sends fuel usage signals as a percentage value, so the gauge cluster is different for each model to account for the different injector sizes and cylinder counts. When they are mismatched in a swap, the gauge cluster doesn't calculate the actual fuel usage accurately, and generally varies proportionally to the injector size. This is why GTE swaps will run out of gas at 1/4 tank, as GE injectors are ~330 CC, while GTE are ~440 CC, so 25% more capacity leads to a 25% decrease in the fuel economy signal sent by the ECU. This can be remedied with an Aristo gauge cluster, but then your speed is in km/h.
Caniac14
15
12-06-14 08:24 PM
soundfx007
IS F (2008-2014)
01-22-12 06:32 AM
draco
01-08-09 05:44 AM
Lexusfreak
03-17-04 09:02 PM
Quick Reply: !!!Question for the GTE swapped guys!!!
