it all depends on how low you go. I am on 20's like a 35 offset with 245/35 and 275/35 tucking a bout a 1/2'' of tire with no rubs what so ever and I am in factory alignment spec. I have the fenders roller and shaved. I was actually looking into these same wheels and to a "fat tire" set up. looks like I cant go that low.
I mean you can get pretty low with that tire set up, but it's going to rub, a lot.
Originally Posted by CBGS3
Any more pics of the setup I'm digging the stance..any tire stretch involved
Yeah they're stretched, ideally you'll want a 245 for the 9.5 & 265 or 275 for the 10.5, but if you plan to drive it as low as that Varrstoen featured car I can't imagine running those tire sizes unless somehow the city you guys are in has no bumps/turns. It's going to chew through those tires.
There here "my boys displaying them at his shop ha" tires here as well but there gonna be exchange for the setup up Danny365N is rockin
Hey Danny are u runnin +22offset n any other mods except for fenders
Yup they're +22 offset, the only thing is I'm using a 10mm spacer to clear Supra brakes up front, so front is +12 technically. Nope I didn't have to do any other mods other than shaving the rear & rolling the front. Camber is all natural from being lowered. I also run BC "BR" with 14/12k spring rate, so that may make a difference.
most definitely will but not sure if I'll keep em on after the snow we jus got up this way...hella pot holes bro....but I will take some of the test fitting n stuff
yea I understand that but right now my front tires are way to big at the moment. running 245 35 20 and they are rubbing on dips on the fender. looking for a little stretch but have the diameter as the rear or close to it. plus my offsets are very conservative.
