Where Can I Find Original Aristo Oem Parts
Old 02-09-15, 11:06 AM
juvi22003
juvi22003's Avatar
Default Where Can I Find Original Aristo Oem Parts
As the title said, where can i find original Aristo oem parts?
Any help would would be greatly appreciated please post links or names below, Can be local or international
Old 02-09-15, 11:53 AM
NorthStyle
NorthStyle's Avatar
Your best bet would be Yahoo Auctions Japan. Unless you know someone in Japan, I always refer people to either Kunio at GTR Garage or Jesse Streeter at... Jesse Streeter (aka Streeter Corporation). Hope that helps.
Old 02-09-15, 01:16 PM
mlracing
mlracing's Avatar
And if you're after large parts (ie bumpers, exhausts, oversize etc) a friend of mine that runs Japanese Classics LLC brings over containers regularly - https://www.facebook.com/JapaneseClassicsLLC?fref=ts
Old 02-09-15, 01:53 PM
juvi22003
juvi22003's Avatar
Thanks fellows i'll be sure to check these out.....
Old 02-09-15, 02:27 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
theres a few places down south i thought west palm and fort lauderdale? the fort lauderdale shop sells all aristo engines and parts..
Old 02-16-15, 07:01 AM
juvi22003
juvi22003's Avatar
Is it drag international? Thats the only one i know but they all used parts.
Old 02-16-15, 07:36 AM
juvi22003
juvi22003's Avatar
Can you guys help me with part numbers for my 97 aristo 2jz-gte:
TIMING BELT
WATER PUMP
CAM SEAL
CRANK SEAL
VVT-I GEAR
Old 02-16-15, 01:57 PM
tmf2004
tmf2004's Avatar
TIMING BELT
WATER PUMP
CAM SEAL
CRANK SEAL
VVT-I GEAR
i would probably contact Drag International in Fort Lauderdale for parts and also Ebay..
Drag does a lot of swaps from what i heard and heard good things about them...
Old 02-18-15, 02:16 PM
LexiBlue
LexiBlue's Avatar
Drag international Aka team orange davie fl. they have everything you will need for Toyota aristo . Larry great guy prices are easy on the wallet I brought my 2jgte vvti swap from him.
Old 02-18-15, 02:18 PM
LexiBlue
LexiBlue's Avatar
tfm2004 you are right they do a lot of swaps on lexus, Nissan, mazda pretty much all jdm cars.
Old 02-18-15, 02:24 PM
LexiBlue
LexiBlue's Avatar
everything you need can be purchase for 93-98 supra twin turbo seals timing belt water pump vvti cam gear can be purchase from lexus
Old 02-18-15, 03:51 PM
juvi22003
juvi22003's Avatar
Thanks guys i already hit up drag international and they aint cheap lol but i might just have them do the work anyway i'm just trying to gather all the parts.
The VVTI cam gear i found here
http://www.driftmotion.com/product-p/dm3058.htm
I been emailing back and fourth with sewell and they helped me out a lot. The only thing im still confuse about is the water this what they sent me:
http://lexus.sewellparts.com/accesso...1998/4475.html
the part number for lexus gs is 16100-4987683 and for the supra is 16100-49847. From my studies and what LexiBlue mentioned above the supra part number will work but what sewell sent me was totally different. So is the water pump for the 98 GS same as the supra/aristo?
Old 02-18-15, 04:21 PM
LexiBlue
LexiBlue's Avatar
are you doing a twin turbo swap if so the water pump is different then the non turbo
Old 02-18-15, 04:32 PM
tmf2004
tmf2004's Avatar
he bought a RHD aristo... probably gathering parts for maintenance
Old 02-18-15, 07:11 PM
guezroks
guezroks's Avatar
With parts, often makers add additional back end numbers ( in the case of that water pump) or even switch part # entirely ( Mercedes per se)
Quick Reply: Where Can I Find Original Aristo Oem Parts
