annoying humming noise
Old 02-08-15, 08:38 PM
islexusred
islexusred's Avatar
Default annoying humming noise
Hey guys recently removed my rear differential on my 98 gs400 to swap the OEM bushings with figs ones! I completely removed the diff, everything went well but now after I installed everything back on I've been noticing humming noise coming from the rear end that wasn't there before! Did I not install it right? Everything is snog and no lose parts or shaky parts! Is there any specific way to mount a rear diff?
Old 02-08-15, 08:41 PM
sam12345
sam12345's Avatar
May be the consequence of stiffer bushings. Stiffer bushings less noise damping?
Old 02-08-15, 09:44 PM
islexusred
islexusred's Avatar
So you're saying the humming noise are vibrations transmitted into the cabin by the Polyurethane bushings?
Old 02-08-15, 09:45 PM
islexusred
islexusred's Avatar
Anyone else experiencing that after installing figs diff bushings?
Old 02-09-15, 10:09 AM
Behemoth7
Behemoth7's Avatar
Same thing happened to me... Your diff is worn out, the poly bushings help amplify it. Do you get the humming noise while accelerating and when you let off the pedal at certain speeds? Me too...
Old 02-09-15, 04:16 PM
islexusred
islexusred's Avatar
Yeah. That's exactly what's happening to mine! Did u replace u diff?
Old 02-10-15, 10:02 AM
Behemoth7
Behemoth7's Avatar
Yup and the used replacement is doing the same thing... My advice to you is find a local mom and pop shop that will warranty the labor and parts of a used unit, that's what I'm going to do. Keep going through used ones until you find one that works.. Lol
Glad I'm not the only one with this issue.
Old 02-16-15, 01:15 AM
islexusred
islexusred's Avatar
On the new differential, did u transfer your figs bushings or were you using the OEM bushings that came with the diff!? Because on my gs4 the humming noise still present even after throwing the car on neutral, and I remember tightening the e-brake tensioner on the rear tires, I wonder if that's my issue...
Lowlexus
Suspension and Brakes
10-15-13 05:21 PM
rickhughe9
02-07-11 01:42 AM
dohc3ltt
02-14-06 04:34 PM
white ice
08-14-05 07:58 PM
Quick Reply: annoying humming noise
