Lower motor mounts hep!
Old 02-16-15, 05:26 AM
wbmx1981
wbmx1981's Avatar
Originally Posted by angus
I think the mistake you are making is you can only lift ONE side at a time - as someone else said the 300 are easier than the 400, I have done lots over the years and recently did 2 sets of 400 mounts.
Do use a piece of at least 2x8 under the pan to avoid denting it with the jack ( I know you said 2x4)
Thanks for the response. Actually, I was using a few 2x4's shacked on top of each other and placed them under the oil pan for the lift. Last night, I re-read all the mount replacement threads, and yeah I did come across a member that stated once the engine was up he used a crow bar to tilt the engine just enough to get it out (I assuming this is what you mean by lifting one side at a time). I will give it another try using the ONE side at a time method.
Old 02-17-15, 06:39 AM
STREETGS
STREETGS's Avatar
Originally Posted by wbmx1981
I attempted to replace my motor mounts on my 99 GS300. I had to stop because I could not get the mounts out. I was able to remove all the nuts, lift the engine with the 2x4, I even lifted the transmission a bit just so the engine and tranny were both level (I read this in a previous post). I could wiggle and twist the mounts, they were completely loose and ready to come out, but I needed an extra inch and half or so and I couldn't get up because the engine was already touching the firewall. I don't want to take my car in although I was quoted $295 for all three mounts without parts. I've done all my work in my garage (timing belt, shift solenoid, LBJ's, blah blah) so I'm handy and somewhat mechanically inclined. What am I doing wrong?
same thing happened to me,
did u find a way?
Old 07-08-15, 12:02 AM
lexo98
lexo98's Avatar
Hey guys. I'll be changing my mounts in a couple days. Anyone else want to chime in? Seems like mixed results and any info will help.
Thanks
Old 07-08-15, 05:48 AM
STREETGS
STREETGS's Avatar
i also read the same thing that u must lift once side at a time a use a pry bar to tilt it to one side to get that extra inch and 1/2
anyone has a d.i.y on this??
Old 07-08-15, 12:39 PM
wbmx1981
wbmx1981's Avatar
Default Mounts Done
I got this completed back in February, but never updated this thread. My car is a 99 GS3.
I was told over and over the steering rack did not have to be moved, but I did to get more room.
1. Loosen the top nuts of the motor mounts, but do not remove (yet). Use a short handle ratchet to maneuver better. Remove the oil filter for more access on the driver side.
2. Jack up the vehicle
3. Safely and securely place vehicle on jack stands
4. Remove the splash guard from under the engine
5. Remove the black cover tabs from the cross member to gain access to the lower two mount nuts.
6. Remove the lower mount nuts from each side of the cross member.
7. Get a 2x4 wood block and place it on the jack head and lift the engine from the oil pan.
8. Lift the engine until the engine touches the firewall.
9. You will still need more clearance to remove the engine mounts so don’t stress.
10. Listen and read this very carefully - remove the top engine mount nut.
11. Remove the member brace
12. Remove the steering rack from the cross member, I used an extra jack stand to hold the rack, so it would not dangle.
13. Loosen the 4 nuts holding the cross member to the frame
14. Now get a breaker bar or a long pipe and wedge it between the cross member and the oil pan, the cross member will feel springy and allow the clearance you need to get the mounts out. The cross member will move because the lower control arm will allow it to flex downward.
15. Install in reverse order.
PM me if you need further help
**NOTE** do the transmission mount too for best results.
**These are not my pictures. I found these on the my.is site**
Attached Thumbnails Lower motor mounts hep!-mount-top-nut.jpg   Lower motor mounts hep!-mount-top-nut2.jpg   Lower motor mounts hep!-tabs-lower-nuts.jpg   Lower motor mounts hep!-lifting-the-engine.jpg   Lower motor mounts hep!-rack-loose-cross-member-loose.jpg
QLex300 (03-27-23)
Old 07-12-15, 12:22 AM
lexo98
lexo98's Avatar
Just did my mounts today. I tried to re-create the wheel at first and do what I thought would be a quicker way. Ultimately I ended up just droping the front cross member. One thing I would definitely recommend is that when you are installing the new mounts place the bottom in first. I tried to get the top into the mount bracket first but it was much easier putting the botton in first.
QLex300 (03-27-23)
Old 07-12-15, 05:35 AM
wbmx1981
wbmx1981's Avatar
Good job man! I tried avoiding the crossmember too, but it was easier to just move the thing out of the way.
Can you feel the difference?
Did you do the transmission mounts?
Old 07-12-15, 12:39 PM
lexo98
lexo98's Avatar
I did do the trans mount also. The front mounts completely came apart during removal and the trans mount has one side torn. I'm waiting a few days to see if all the vibrations are gone but so far so good. I never noticed how much the engine rocked during start up with the broken mounts. Now cranking is smooth. BTW the hose that comes out of the power steering resevior was so brittle it split when I lifted the motor. I have 240k and it was so brittle I'm glad it broke now. I'm gonna go through and change all hoses now.
QLex300 (03-27-23)
Old 07-13-15, 06:23 AM
wbmx1981
wbmx1981's Avatar
Same here, all of my three mounts were way done. My transmission mount was broken in two pieces and my engine mounts both dried out and cracking. After changing mine out, I can feel the difference. I have little to no vibrations when idle. I saved a bundle doing it myself too.
QLex300 (03-27-23)
Old 03-27-23, 12:58 AM
v86L
2nd gear
v86L's Avatar
I would like to use these engine mounts on another car. Is it possible for someone to give me the height of these mounts not including the studs please?
Old 04-10-23, 09:32 AM
FEPerron
3rd Gear
FEPerron's Avatar
I think it's a bad idea to lift the engine from the oil pan. You could compress the gasket and cause an oil leak later. Better to lift with a chainfalls from the top.
Old 04-10-23, 11:40 AM
lexo98
lexo98's Avatar
I agree but considering the tools most of us have I think the majority of us just put a block of wood under the pan and went for it.
jwigley
RX - 1st Gen (1999-2003)
11-04-18 07:43 AM
oversteer
74
09-06-15 07:06 PM
EpixINC
Suspension and Brakes
108
05-27-15 01:36 AM
Hils400
28
09-25-11 09:10 PM
tritron
07-23-08 08:17 PM
Quick Reply: Lower motor mounts hep!
