I found a couple threads about this with no responses. Will an axle back exhaust off an LS or SC fit a GS? Angle and inlet diameter are the two hangups I could foresee.
I'm buying an SC axle back exhaust tonight so I can post what I find.
The one on Northwest Lexus Owners Facebook page? For that price, its worth the gamble. If the SC exhaust isn't too far off, an exhaust shop could probably modify it to fit.
So it won't work. The GS has vertical flanges whereas the SC has horizontal flanges. The GS also has a downward angle on the axle pipe whereas the SC is horizontal.
You could cut off the flanges, rotate 90 degrees, and weld back on. While the flanges are off, you could shorten/lengthen the pipe to fit your needs. Then either bend or pie-cut the pipe to the angle you need...
True. At that point, though, you may as well look at what cost will be and if a GS axle back would end up costing the same. I'm going to pull one of my mufflers and take a look but eyeballing last night showed it's not direct.
