Stupid question about ABS sensor/hub assembly
Old 01-12-15, 03:50 PM
NoUltimatu
NoUltimatu's Avatar
Question Stupid question about ABS sensor/hub assembly
I am trying to remove the front left hub so I can have a shop push out the bearing.
I have gotten it to where just the ABS sensor is on and holding me from pulling out the hub.
I have removed the 10mm bolt from it. It seems to spin freely around the ABS line. How do I remove it?
Second question is: when I go to the shop, will I need just 1 part (bearing) or is it a bunch of parts? Because the diagram shows about 7 parts going in to that. Thanks
Old 01-12-15, 09:35 PM
NoUltimatu
NoUltimatu's Avatar
Nevermind. Figured it out by watching this Toyota video. Apparently I need to keep wiggling and maybe pry it off.
Old 01-13-15, 08:15 AM
FrankT
FrankT's Avatar
Provide them with a new spindle nut...
I believe the old one is staked and will damage the threads if reused.
Old 01-13-15, 10:39 AM
marshun
marshun's Avatar
the old one is notched, you can reuse it.
have fun. wheel bearings are a pain
Old 01-13-15, 01:49 PM
FrankT
FrankT's Avatar
The nut is a non reusable part costing less than $5.00. Yes folks will reuse them, I have in the past and in turn ruined the threads on the spindle.
My advice is always based on personal experience so take it for what it's worth to you...
gally1998
08-07-19 04:04 PM
songlou
01-09-16 08:23 AM
ebnub
09-11-10 08:04 PM
lexsc3
Suspension and Brakes
09-08-10 03:43 PM
billcwood
02-28-06 06:05 PM
Quick Reply: Stupid question about ABS sensor/hub assembly
