2001 lexus gs300 rough idling and shutting off
Old 01-01-15, 05:10 PM
lildorsey1
lildorsey1's Avatar
Default 2001 lexus gs300 rough idling and shutting off
My 2001 lexus gs300 vsc,vsc off and engine light is on. When car is idling the car runs rough shakes and cuts of.But drives perfectly fine when driving above 2 rpms and at normal speeds. I got 2 oxygen sensors.
Old 01-02-15, 05:43 AM
czr73
czr73's Avatar
You need to adjust your Throttle Position Sensor (TPS). It's located right in front of your throttle body (TB). Take a multi-meter and adjust to .70, I believe. Search TPS Adjustment on this forum if you need a step by step on this. I started a thread on this topic in the past.
It could also just need maintenance such as a good cleaning of your TB. I read another thread where the guy had water in his gas tank and purchased an additive to get rid of the water in his lines and it worked, no more stalling and increases power.
Old 01-02-15, 10:25 AM
lildorsey1
lildorsey1's Avatar
Could that be the cause of check engine light
Old 01-02-15, 11:45 AM
FrankT
FrankT's Avatar
Get you DTC scanned.
To me your discribing a large vacuum leak. Check the intake tube after the MAF sensor up to the throttle body.
Good luck...
Old 01-02-15, 01:27 PM
lildorsey1
lildorsey1's Avatar
i goiing to get it done on monday but lately i wold rev the engine at a constant rate for like 5 mins then it will stay above 1 to 2 rpms it runs good and dont shake or cut off when stopping
thebes
09-11-17 11:57 AM
Obarber33
07-28-17 06:57 PM
dkobryant
01-24-16 04:23 AM
Jbthompson
04-27-15 08:50 PM
captaincru
05-14-09 06:00 AM
Quick Reply: 2001 lexus gs300 rough idling and shutting off
