How to turn traction control / VSC off?
I was wondering how I would turn traction control off? I know there is the VSC button in the center console area but when I press that button, nothing lights up on the dash to let me know it was turned off? Has anyone run into this before or know how I could approach this?
Does the 'VSC off' light turn on briefly when you first start the car? If it doesn't, the bulb might be out, but if it does you've probably got a wiring issue with the switch.
No "VSC OFF" indications on dash. Got it.
But is the VSC control actually working?
To be sure try this:
Spray some armor all on both rear tire treads (so you'll loose a little traction when you take off). Do you hear/feel the abs kicking in when the tire begins to spin? If so the VSC is off. Press the VSC button again and repeat.
This should help you determine whether VSC is operating correctly.
So I've narrowed it down to the bulbs in the "warning" section of the cluster. Does anyone have any links on how to replace these bulbs?
I figured this out by watching a video on YouTube of someone starting up their 2GS and noticed their lights for vsc came on but mine don't during starting up the car.
