P1128 CEL and I've replaced all TB sensors HELP
Old 12-01-14, 04:13 PM
rorygs300
rorygs300's Avatar
Default P1128 CEL and I've replaced all TB sensors HELP
So after replacing my door lock actuators and disconnecting the battery I threw a p1128 cel in my 2000 gs300. I've since replaced the TPS, throttle control motor, and pedal position sensor, and It doesn't fix the problem. I don't know what to do next, and this is getting frustrating.
Old 12-01-14, 04:18 PM
Bhubb18
Bhubb18's Avatar
Bad battery / alt could be it, may want to look into it.
Old 12-01-14, 04:31 PM
rorygs300
rorygs300's Avatar
Battery is just a few months old, I checked it with a volt meter 12.5 volts 14.5 volts when running
Old 12-01-14, 06:41 PM
lexo98
lexo98's Avatar
Everytime I disconnect my battery my car runs like ish. I have to disconnect and reconnect the battery a couple times and give it gas while it misfires for a few seconds. Then poof good as new. Codes turn off and runs great.
Old 12-01-14, 07:46 PM
NotADood
NotADood's Avatar
Lexus master tech here,
while I have never seen this code personally on a GS300, according to Toyota's repair manual, it should either be the throttle body, or the throttle control motor.
Good news for you however, Lexus has a warranty extension on most Lexus vehicles with electronic throttle control. This includes all GS models from 1998-2010. If it is found that the throttle body or motor is at fault, it is covered under warranty for UNLIMITED MILES until AUG 2016.
Old 12-02-14, 12:28 PM
GS4_Fiend
GS4_Fiend's Avatar
Do you have the TSB number?
Old 12-02-14, 12:59 PM
rorygs300
rorygs300's Avatar
I've fixed the problem the tps was not set correctly which made the code come back up. My car is running great now, I've only owned my car for 2 months so I don't qualify to have my car repaired for free.
aslowdodge
09-11-17 07:17 PM
okiegx
GX - 1st Gen (2003-2009)
12-05-16 05:43 PM
gindyo
ES - 5th Gen (2007-2012)
06-27-16 07:31 AM
innerreef
10-03-15 08:23 PM
Solo2
12
12-02-12 10:23 AM
Quick Reply: P1128 CEL and I've replaced all TB sensors HELP
