GS300 replaced fuel pump car still wont start
Old 10-29-14, 09:24 AM
MikeFig82
MikeFig82's Avatar
Originally Posted by Spence1978
Yes it's not a immobilizer issue. The screw looks flush so if I don't have fuel pressure then what?
Just to be sure have some one try to start the car. You can watch the screw if it pops up or not. If it's not doing anything. Then I would disasble the pump assembly again and check everything over. Make sure the O rings are where they need to be and test the Pump with an Muliti meter for OHM 's specs. Double check everything in the assembly maybe you have fuel shooting out at the assembly and the pump isn't pumping it to the fuel line.
Old 10-29-14, 01:25 PM
Spence1978
Spence1978's Avatar
Could a person take the top hose off of the fuel pump and cover it to see if its sprays gas out?
Old 10-29-14, 03:19 PM
freshmoney
freshmoney's Avatar
Sorry to hog your thread. I figure why start another post at the same time with very similar issues.
I checked the end of my fuel rail and the screw raises as someone tries to start the car. Does that confirm that new pump and filter are not the issue?
Took off timing cover and my belt is still intact.
Old 10-29-14, 05:48 PM
MikeFig82
MikeFig82's Avatar
If it's raising then you should have fuel pressure. I would also suggest leaving the key to the on position for 5 min. Then try to start it. The only thing I can think that it's a immobilzer issue.
Your obviously getting fuel to the rails. I would check for spark next. Do you have a CEL light on? Check your coils are connected properly. Could also be a Cam sensor or Crank sensor gone bad.
Old 10-29-14, 06:02 PM
MikeFig82
MikeFig82's Avatar
When i installed my new assembly. I think it did shoot out some from that top hose.
Old 10-29-14, 08:05 PM
Sonic_RC
Sonic_RC's Avatar
I have a similar issue. Ever since I upgraded to a Aeromotive fuel pump for my engine swap my car runs out of gas when its only at a 1/4 tank
I was told it might be the transfer tube or the float. Any other ideas?
Old 10-29-14, 09:20 PM
freshmoney
freshmoney's Avatar
I tried leaving the key in the on position for 5 mins. Now my alarm light blinks with key in the ignition... You might be right about the immobilizer.
Old 10-29-14, 09:25 PM
lexo98
lexo98's Avatar
Ever since I replaced the fuel filter/ sock i run out of gas at about 1/8 tank when the car isn't level.
Old 10-29-14, 09:56 PM
iamkhanz
iamkhanz's Avatar
for fuel gauge issue, the level sensor maybe off.. mine wasn't working for a while..
Also if it's just cranking... just a thought, is your key functioning properly... sometimes, if the chip in your key isn't programmed right this same issue could happen, maybe try another key for your car just to check. Rare that this is issue but atleast rule it out.
Old 10-29-14, 10:11 PM
MikeFig82
MikeFig82's Avatar
I think to reset the immobilzer is to lock and unlock the drivers door twice with your key. After lock it again and check if your security light blinks again or stays off.
Another is to try the passenger door lock and unlock cycle twice with your key. Then try to start.
Putting the key in the ignition and to the "on" position but don't try and crank. Leave it in that position for 5 minutes, switch off and then try to start.
Old 10-30-14, 07:29 PM
freshmoney
freshmoney's Avatar
Thank you everyone for your help... Club Lexus wins again
Old 10-31-14, 08:54 AM
freshmoney
freshmoney's Avatar
Went out this morning to test drive and it didn't start. I left it running yesterday and turned it back on a couple of times. Couldn't take it on the road yesterday I had my one month old didn't trust it. Back at it later
Old 11-03-14, 11:14 AM
Spence1978
Spence1978's Avatar
Fixed!!!!!!!!
So i pulled the new pump and looked at the old pump to see what i might be missing. On the old filter there was a little grommet that i didnt put on the new filter. Added that and re installed and the car fired right up.
02msmg3
11-01-17 08:02 AM
Deathrow23
08-17-15 01:08 PM
99gs713
12-17-13 08:10 PM
OG_SC300
Performance & Maintenance
11-16-11 06:03 AM
WVGS4
09-06-07 04:26 AM
Quick Reply: GS300 replaced fuel pump car still wont start
