Rear rotor stuck- not placed on hub correctly
Old 10-18-14, 09:26 PM
Zoolander
Zoolander's Avatar
Default Rear rotor stuck- not placed on hub correctly
Whoever did brakes on this car before me did not line up the two pilot holes so I cannot pop it off in the ways commonly suggested. I have beat on this a million different ways with no luck, it is stuck on here. What else can I do that hasn't been referred to in other threads to get this rotor free?
Old 10-19-14, 12:55 AM
geeznuts
geeznuts's Avatar
Release the parking brake
Old 10-19-14, 01:11 AM
Zoolander
Zoolander's Avatar
Parking brake is released.
Old 10-19-14, 10:50 AM
lexo98
lexo98's Avatar
Can't see enough of the rotor in your pics but aren't some of the holes in your rotor threaded? They don't screw into the hub. That is so you can put 2 screws in it. One at 12 o'clock and one at 6 o'clock and take turns screwing them in until the rotor breaks free.
Old 10-19-14, 01:02 PM
marshun
marshun's Avatar
ball peen on the center of the rotor. should pop off easily.
Old 10-20-14, 04:37 AM
angus
angus's Avatar
+1 on the hammer, if you are CERTAIN that the parking brake is released - and I mean that you have turned the adjusters to slack - then beat it and it'll come off - I don't mean too much, a few good hits should be all you need.
Old 10-20-14, 09:22 AM
GSGenesis
GSGenesis's Avatar
I've had mine stuck a few times. Like they said, just first spray some wd-40 around the center hole for the hub trying to get some to go inbetween, wait a few minutes and just slam the rotor with a sledge right in the hub area of the rotor to shock the bond. Hell if your tossing the rotors then hit them anywhere you must to get them to break free. Sometimes a rubber mallet just doesn't do the trick...
Old 10-20-14, 10:40 AM
Zoolander
Zoolander's Avatar
I'll go back to the hammer method and report back. Thanks! I know the parking brake is good because the PS side came off no issues. Just the DS side giving me grief.
Old 10-20-14, 10:42 AM
RamAirRckt
RamAirRckt's Avatar
IIRC isn't the rotor threaded, so just start a bolt in and it will pop it right off?
Old 10-20-14, 03:35 PM
Zoolander
Zoolander's Avatar
Went to Harbor Freight and bought a 4lb sledge. Took about 12 seconds. I have a new favorite tool. Thanks, all!
Old 10-21-14, 02:25 AM
angus
angus's Avatar
Yup, 4lb sledge is a have of mine too.
BFH!
Old 10-22-14, 10:48 AM
KeyKeeper
KeyKeeper's Avatar
Cant stop.........hammer time....(you know you started humming it).....
Old 10-23-14, 01:07 AM
GSGenesis
GSGenesis's Avatar
Haha wow now! Slow down, you won't be needing that thing anymore really... Go ahead and put her away somewhere lol... Jk Gj glad to hear...
Old 10-25-14, 08:30 AM
marshun
marshun's Avatar
lol. mini sledges are fun. but i think thats a bit much. lol
Old 10-25-14, 08:40 AM
RamAirRckt
RamAirRckt's Avatar
On my K2500 Suburban I had to use a 16 lb sledge just to get the wheels off..... the drums weigh 66 lbs each.....
CPMD
03-27-23 04:27 PM
sha4000
05-04-17 04:54 PM
mercurymet
IS F (2008-2014)
01-23-14 10:37 PM
trhs75
RX - 1st Gen (1999-2003)
09-21-09 08:46 AM
Quick Reply: Rear rotor stuck- not placed on hub correctly
