Pics of my GS430 with GS-F wheels...spacer question
Old 10-05-14, 09:15 AM
Straight6
Straight6's Avatar
Default Pics of my GS430 with GS-F wheels...spacer question
Just installed GS-F wheels on ny 2nd gen, what's the safe limit on spacers and if anyone can suggest which ones to get and where to get them. Just want to bring them out a little bit more. Thanks
Attached Thumbnails Pics of my GS430 with GS-F wheels...spacer question-image.jpg
The following 2 users liked this post by Straight6:
GSpearlwht (07-06-19), NexusD (09-30-19)
Old 10-05-14, 11:42 AM
Bjerke
Bjerke's Avatar
Looks good. whats the dimesion on the tires.
QLex300 (01-09-22)
Old 10-05-14, 12:56 PM
702GS
702GS's Avatar
+1 info, we need it
Old 10-05-14, 01:26 PM
Straight6
Straight6's Avatar
Wheels are 19x8 front and 19x9 in the rear. Tires are 235/40/19 fronts and 265/35/19 rears.
Ofcourse no rubbing issues.
GSpearlwht (07-06-19), QLex300 (01-09-22)
Old 10-05-14, 02:06 PM
NorthStyle
NorthStyle's Avatar
What do you mean by "safe limit"? If you're referring to how wide of a spacer you can run on the stock lugs without getting either extended lugs or bolt-spacers I wouldn't go past 5mm. However, if you're just looking for "max" whatever then it comes down to what you're comfortable running. I've seen 50mm+ bolt on spacers so someone's probably ran them before...
As for which ones to get, Ichiba or H&R make quality parts. Also, I'd recommend getting hub-centric spacers.
Old 10-05-14, 04:48 PM
Straight6
Straight6's Avatar
Yes that's what I meant, limit on spacer width on the stock studs. Assuming I go max at 5mm, is there a size specifically for our cars ie Toyota/Lexus? Do you know the average cost? Thanks for the feedback.
Old 10-05-14, 04:55 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
Good looking wheels! PS they're IS-F wheels (no such thing as a GS-F yet)
https://www.clublexus.com/forums/gs-...gen-gs430.html
https://www.clublexus.com/forums/per...0-wannabe.html
Old 10-05-14, 05:04 PM
400DGRZ
400DGRZ's Avatar
I believe those are GS F-Sport package wheels.
GSpearlwht (07-10-19)
Old 10-05-14, 05:09 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Yeah, you're probably right now that I look at 'em closer! I saw the beveling on the edges and thought IS-F and not f-sport
Old 10-05-14, 05:10 PM
Straight6
Straight6's Avatar
400DGRZ said it right, these are F-Sport package wheels on the 14 GS. I did have IS-F wheels prior..
Old 10-05-14, 05:27 PM
702GS
702GS's Avatar
Those ones look grand! Same size as the current set?
Old 10-05-14, 05:31 PM
Straight6
Straight6's Avatar
19s but half inch wider...19x8.5 and 19x 9.5. Too bad I had to return them to a friend. Either way
I'm happy with either one. Tires were not as wide on that set,
Old 10-05-14, 08:02 PM
NorthStyle
NorthStyle's Avatar
The centerbore for our vehicles is 60.1 and the lug sizes are 12x1.5. The cost all depends... I purchased my set (4) of 5mm hubcentric spacers for appx $36 shipped on ebay. You may be able to find a deal if you look hard enough and are patient although 5mm's are generally cheap.
Old 10-05-14, 08:12 PM
Straight6
Straight6's Avatar
Awesome info. I'll look into how much I need to push the rears out and update when I get them, thanks
Old 10-08-14, 12:22 PM
GRANYZ400
GRANYZ400's Avatar
First of all, those wheels look great! Second, here's an old pic of before and after the 25mm H&R DRM spacers I installed over a year ago. I have since changed tires (looks better) and my wheels are black. Anyway, I liked the 25mm's because it's the smallest size you can get where you bolt the spacer on and get "new" studs without pressing the existing ones out. I have been running them for over a year with no issues. I check the torque when I change rotate the tires and I have never had one come loose. Rock solid at 85ft-lbs.
Quick Reply: Pics of my GS430 with GS-F wheels...spacer question
