Car shuts off at operating temperature
Old 10-03-14, 05:14 PM
Beef356
Beef356's Avatar
Default Car shuts off at operating temperature
I have a 1999 gs300 with almost 200,000 miles and it's been giving me problems lately. Radiator developed a Crack so it was replaced .Car starts fine when cold idles fine and doesn't make any strange noises .after about 15 minutes of running the car dies but restarts and dies immediately. Car wont run unless the car has cooled down .temperature Guage never goes over the middle . The fans never turn on when the car reaches operating temperature . When I turn the ac on the fans work and car stays on but upon acceleration around 2000 or 3000rpm the car backfires and cuts off .
Old 10-03-14, 06:12 PM
marshun
marshun's Avatar
so just a rad change and its been this way? have you bled out the system good?
Old 10-04-14, 02:31 PM
Beef356
Beef356's Avatar
I will try to bleed it again tomorrow.
Old 10-04-14, 04:33 PM
burny
burny's Avatar
what about codes? any codes? You ever replace your coil packs?
Old 10-04-14, 05:53 PM
Beef356
Beef356's Avatar
No codes and the coil packs haven't been touched since I've had the car . Bad coil packs would cause the car to shutdown?
Old 10-04-14, 07:05 PM
burny
burny's Avatar
yes they will cause it to shutdown once at operating temp. The fail-safe operation for P1300 cuts the fuel. If you run the codes and see P1300, I would tell you it is a coil pack and not the igniter.
Old 10-04-14, 07:41 PM
Beef356
Beef356's Avatar
No codes and I lightly tapped on the ignition module with the ac on and it didn't cut off .
Old 10-05-14, 07:42 AM
burny
burny's Avatar
you could always take the igniter loose and clean the dust off it. Sits right there on top. How is your MAF sensor as far as being dirty?
Old 10-05-14, 08:08 AM
Beef356
Beef356's Avatar
Clean the igniter with Electric cleaner or just dry wipe ? I've cleaned the maf and unplugged it with the car on and it ran worse.
Old 10-05-14, 09:28 AM
burny
burny's Avatar
i would just dry wipe it
Old 10-05-14, 02:09 PM
Beef356
Beef356's Avatar
My car had to be jump started because of sitting for a while So I bleed the system and the fans finally came on by themselves. So I let the fans cycle on and off about 4 times then the car studdered like it wanted to cut off and the fans came on and it kept running. Then it cut off. So I started it again and it ran for a while the fans coming on and off like it's suppose to and it cut off again.
Old 10-05-14, 02:22 PM
burny
burny's Avatar
I'm guessing now but do a little searching on here or google on the ECTS - Engine coolant Temperature sensor.
Old 10-05-14, 10:17 PM
Beef356
Beef356's Avatar
I'm familiar with it. I've changed it on my ls400 a few months ago. It won't hurt to try
Old 10-06-14, 03:51 PM
Beef356
Beef356's Avatar
I made a list of things to start checking
Fuel pump
Coil packs
Fuel filter
Cam sensor
Crank sensor
Is there anything else I should check ?
Old 10-06-14, 04:58 PM
vijayn
vijayn's Avatar
Hey mate
Have you checked all the main relays for Fuel pump and ECU? Check to see if they have intermittent play with a multimeter/scope when your car is warmed up.
If there is no codes and the engine suddenly dies that could mean that the ECU itself is not able to log a code because the problem is itself. Also check grounds and main feeds to the ECU too.
Quick Reply: Car shuts off at operating temperature
