2001 GS300 factory subwoofer is not working.
Hello,
I recently purchased 2001 GS300; for some reason, the audio system works fine, except for subwoofer. All of speakers work but subwoofer. The subwoofer does not appear to have any physical damage. Is there a fuse just for a subwoofer amplifier? What things should I check?
Thanks.
Thanks.
It's either seized or it was unplugged, check the wires for it, the plug you can't get to without taking the deck lid off. Either way u should upgrade since it prolly will blow anyways.
So there is no fuse that is only for subwoofer amplifier; there is only one fuse for the entire audio system, right?
Update (Problem found)
First, I unplugged the subwoofer connector from the audio amplifier, then I connected a function generator and fed the signal into the subwoofer connector. The subwoofer started playing the signal. At this point I knew that problem is in the audio amplifier. Sure enough, after taking it apart, the Toshiba TA8225H audio amp chip is burnt. I can buy this chip, and fix it (being an electrical engineer helps) but the used audio amplifier (entire unit) is about $20 on eBay - so I'l just replace the entire unit.
I hope this info helps someone with similar problem.
Below are the video of subwoofer test, and a photograph of burnt IC.
The audio amplifier is located behind the glove box, on the right side.
01gs3
07-25-11 11:48 AM
swong46
02-22-11 10:55 AM
