Strange audio problem, is it unit failing?
Old 09-16-14, 07:52 AM
maxx430
maxx430's Avatar
Default Strange audio problem, is it unit failing?
More often than none, when I start my car, the volume is very low or non existence. The moment I gently adjust the volume (decrease or increase ever so lightly), the volume jumps up to the max in less than a second and blast music through the speaker. It scares my wife every time and she thinks i do it on purpose. I have a 2001 GS430 with ML and navigation. Is my unit slowly disintegrating?
Side note- sometimes the audio present on my ML screen would disappear as though someone has increase the EQ so much that it is off the display.
Old 09-16-14, 08:09 AM
offbad
offbad's Avatar
this happened in my sienna, it was the volume control **** that didn't work properly all the time.
ended up getting a 2din for it.
Old 09-16-14, 08:21 AM
dungut
dungut's Avatar
You describe the exact symptoms of a failing/failed mark levinson amplifier. Replace it, have it repaired, or go aftermarket. Be careful if you buy a used one, the newer ones from 03-05 have updated internals to prevent this problem.
Old 09-16-14, 10:56 AM
maxx430
maxx430's Avatar
thanks for the tip. What other lexus model will have an ML amp that is compatible with our cars and contains the new updated internals?
Old 09-16-14, 04:24 PM
ThomasGS4
ThomasGS4's Avatar
Bingo. The disappearing EQ settings is a dead giveaway.
HaerdenC
01-11-18 02:17 AM
pbxcomm
10-12-16 12:25 PM
PolishDude
07-20-16 10:19 AM
komodo
05-26-13 09:15 PM
marky2mark
01-12-11 09:42 AM
Quick Reply: Strange audio problem, is it unit failing?
