One more steering shake thread
Old 08-21-14, 12:44 PM
bartsitars
bartsitars's Avatar
Default One more steering shake thread
Alright, I have read 10000 posts on this issue and I have replaced the ball joints, outer tie rod ends, #1 and #2 control arms. I can't get the jam nut off to tighten the rack and it seems like the rack bushings are fine. My symptom (this is where I could not find a thread) is that SOMETIMES when I step on the brakes, the steering wheel shakes quite a bit. I hesitate to think that it's the rotors because it doesn't happen all the time. What are your thoughts? PS, no shake while driving at all, although I do seem to correct the steering at highway speeds more than I would like.
Old 08-21-14, 12:51 PM
Lexusjg1
Lexusjg1's Avatar
Could be a bad tire, uneven tire wear or something. Just a thought.
Old 08-21-14, 12:56 PM
bartsitars
bartsitars's Avatar
I should add too, all new tires and alignment done. I even rotated the tires just to rule that out.
Old 08-21-14, 01:18 PM
BigGeigs
BigGeigs's Avatar
I am having a similar problem. I will occasionally get a shake. I ordered some FIGS #2 Caster Arm bushings and steering rack bushings that came in yesterday. I am hoping those will clear it up, but it sounds like you already tried that
Old 08-21-14, 02:18 PM
offbad
offbad's Avatar
happens when you step on the brakes, check the brake components.
Old 08-21-14, 02:36 PM
chico55
chico55's Avatar
It happened to mines to.u have to resurface the rotors..I took it in and they fixed problem..I go to LEX auto in miami fl
Old 08-21-14, 02:41 PM
chico55
chico55's Avatar
The specialize in LEXUS..thats the only place I car my Lexi.great people and very honest. And cheaper than stealership.
Old 08-21-14, 03:32 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
could be warped rotors if they have never been changed.. and the nut on the steering rack is the pre-tensioner nut and you only turn that about 1/8 to 1/4 turn.. you don't take that off
Old 08-22-14, 05:29 AM
DMPesso
DMPesso's Avatar
I'm shocked all these people didnt tell you this already except for chico: it is 1000000% your rotors, do NOT resurface them, thats very unsafe and it decreases the braking power. Just buy new rotors and feel the amazing difference! You can even buy the autozone rotors, anything is better then resurfacing them, dont cheap out on this, ive been there done that. For the price of resurfacing rotors you can buy brand new rotors from autozone. Buy new rotors and you'll be all set! Make sure you get brand new pads as well. You CANT put used pads on new rotors!! If your not trying to spend that much just start with the front rotors and pads and get to the rear another time, only the front can cause the shaking.
Old 08-22-14, 05:33 AM
DMPesso
DMPesso's Avatar
Default .
Just out of curiousity how much did you pay to resurface the rotors?
Old 08-22-14, 07:46 AM
bartsitars
bartsitars's Avatar
Thanks guys, rotors will be next on the list. And just to clarify, I know that rack bolt only tightens 1/8 to 1/4 of a turn. I was referring to getting the jam nut loose.
Bon
08-13-21 07:51 PM
Moarpower
12-17-18 09:26 AM
BoostAddct
Suspension and Brakes
17
10-28-11 09:29 PM
TomLee
SC- 1st Gen (1992-2000)
04-03-10 04:04 PM
Giggzz
07-11-07 08:02 PM
Quick Reply: One more steering shake thread
